04-14-2011, 02:01 PM | #1 |
105
Rep 585
Rumor: F30/F32 M3 to Get Tri-Turbo V6 Engine
So far it seems clear, that the engine of the new M3 would be based on the N55 R6 ... with two possibility that are discussed ... a 3.0ltr. BiTurbo and a 3.5ltr. TriTurbo.
But now there are now rumors in german forums (from someone who has been known to have some good connections to BMW M) that there is an possibilty that the M-GmbH has changed their mind to an totally new and for many totally surprising engine layout .. but a logical one: a 3.3L V6 with 3 Turbos !!! (one general turbo, plus two turbos dedicated to 3-cylinders each) ... there is furthermore the yet not from anyone realized TriTurbo Issue but the rest seems logical ... taking the new M5 4.4ltr. V8 and taking 2 cylinderrs away and you getting an potent 3.3ltr. V6. Greets Uli_HH Last edited by Uli_HH; 04-14-2011 at 03:39 PM.. |
04-15-2011, 01:46 AM | #6 | |
58
Rep 1,230
I believe they see Nissan as a direct performance threat in this competitive market and proof shows that many guys dumped their V8 M3's once the new GTR was released. Check these forums for the ones who switched over.
Sticky is an Idiot
04-15-2011, 03:27 AM | #7 |
86
Rep 1,166
No V8 grunt, the legendary M3 will be in history....
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
04-15-2011, 08:53 AM | #8 |
111
Rep 1,772
A smooth V6 is definitely possible with a 60-degree V-angle. So they can make a smooth V6. However, BMW clearly prefers to set the turbos inside of the V in V-engines (as seen on the 4.4 liter bi-turbo) and I have troubles imagining that they could acheive this arrangement with a 60-degree V.
Lets say they went to 90-degree V angle and did put the turbos in the V, then that is fine, but they would do it with a sacrifice of some smoothness and free-revving nature that BMW is known for. I would be surprised if they do this. My personal opinion on a V6 tri-turbo is that, although technically possible in terms of plumbing with the turbos in the V (not possible with turbos outside the V) I am pretty certain that the heat would be too much of an issue to pull this off. This makes me think that an inline-6 is still most likely. BMW will probably want to make this the first full M-version of a turbo so I can see it being significantly different from the N55... maybe a tri-turbo is in the cards. I think that the most likely thing will be M making their own 3.0 or 3.2 I-6 engine and then pumping the hell out of it with twinturbos. To be clear, I don't think that they will use an N54 or N55 and simply modified it a little this time like they have on the some of the current M-cars. |
04-15-2011, 10:24 AM | #10 |
130
Rep 2,291
04-15-2011, 12:17 PM | #12 |
66
Rep 2,189
actually guys... its their 4cyl engine... x 2...
one in front and one in back... quad turbos. you can actually disable the rear engine for fuel economy. Bmw is currently working on a way to make it all work and still provide storage space in the rear. ppp p.s. can you say perfectly balanced awd beast, hope they keep the weight down.
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
04-15-2011, 04:14 PM | #13 | |
Administrator
6708
Rep 4,201
It seems the one dogma BMW has maintained is to stay away from V6 engines, probably only because of their complete perfection of the i-6. Im not sure the advantage a V6 turbo would have over an i-6 turbo as far as BMW M is concerned. But the way BMW has been going, nothing is impossible, so its something to think about in the back of our minds for sure. In the end, the next M3 is so far away in the timeline, I bet atleast another 10-20 rumors fly in and out between now and then |
04-19-2011, 01:12 PM | #16 |
1109
Rep 1,314
How about a I-6 with a 2 pipe exhaust manifold with a dedicated Turbo on each one making 3 Turbo's total. That would be interesting. They have done so well with their Inlines...why go to a V6? Plus I can't see it sounding good in that configuration.
04-19-2011, 01:13 PM | #17 |
1904
Rep 3,214
Drives: 2018 BMW 440i GC
The M3 is too import to BMW to go and try something ridiculous, even if it was a game changer. |
04-19-2011, 01:17 PM | #18 |
87
Rep 2,464
If you think about it, it makes "sense" to use V6. They'll have 2 or 3 turbos, intercoolers and etc... An I6 takes too much space. V6 will be much more compact.
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
04-19-2011, 01:24 PM | #22 |
(Sold) '00 M Roadster '06 M Coupe '16 M3 '20 X3MC
1547
Rep 2,588
Legendary M3? the current M3 is the only one to ever have a V8, they are just going back to the old M3 engine size but adding turbos.
times are changing, everyone needs to get used to it! The M3 after this one will probably be part electric, what will you say to that? |
