2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding USB port in the center console won't charge iPod
      04-10-2011, 11:16 PM   #1
JPHender
Drives: 1999 528i, 2011 528i Sport
I discovered inadvertently that the USB port in the center console does not charge my iPod. Does anyone know it this is normal?
I've had the car for three months now and keep an iPod nano in the console. This past week, every time I tried to listen to the iPod, it would disconnect after one or two songs and hang, like has been reported in other threads. I finally took a look at the iPod this afternoon and found that the battery was completely dead! even though it has been plugged into the usb port continuously. I tried several cables and none charge the iPod. If this is by design, it is a HORRIBLE design. Why doesn't the usb port provide power out for charging???
      04-11-2011, 03:10 AM   #2
SpawneyGet
United Kingdom
Drives: F10 535d M Sport
I keep my iPod Video in there and it is always fully charged. At first I was going to suggest that you tried official cable but if you have already tried it then go back go the dealer.
Unless it doesn't (fully) support "Nano"...
      04-11-2011, 04:38 AM   #3
raccoonraccoon
Drives: BMW F10, 520d Automatic
my USB port charges my old Ipod Classic fine, but refuses to charge a newer version Ipod...it also doesnt charge my Ipad...I think its a little ridiculous...there should be enough power in that port to charge anything!
      04-11-2011, 04:54 AM   #4
cliveywolves
United Kingdom
37
Drives: 330e M Sport Plus Edition 2020
It always charges my iphone , im using the genuine bmw usb cable dont know if that makes any difference ?
      04-11-2011, 05:02 AM   #5
SpawneyGet
United Kingdom
How much was "genuine" BMW USB cable?
I am using "genuine" Apple cable that I bought from ebay for about £3 and it charges, play and displays everything.
      04-11-2011, 05:10 AM   #6
cliveywolves
United Kingdom
37
From BMW there about £40 ish...
I got mine from an ebay seller for about £25 i think it was....
      04-11-2011, 06:50 AM   #7
pyramid
Indonesia
Drives: Serpent S966
Various Various  [0.00]
Old ipods are using firewire input through its bottom 30pins connector for charging. All newer iPod/iPhone version (since iphone 3G release) uses 5.0v usb input pin. Thanks to Apple for un-notified changes to vendors before they release their newer iPods.
I don't have the F10 yet, but if that USB port in center console "only" meant for iPod, meaning its internal electrical wiring still aiming iPod firewire pin for charging instead of USB. Two options for you, there are some vendor making firewire to usb converter for this purposes, or asked BMW to change to newer electrical wiring/device for iPod related connection. In mercedes, it is only a matter of changing a small electrical device meant for iPod.
But I agree, it should not be happening since F10 was released way after iPhone 3G.
      04-11-2011, 07:19 AM   #8
ghueser
36
Drives: 2014 M5
JP.....
I have a 6th Gen Nano and keep it in the armerest console all the time, continuosly plugged into the USB port, using the Apple cable. To date, I have not had any charging issues and notice when I take it out every other week or so to re-sync with my computer, is always fully charged. Just a guess, but maybe the unit does not shut down or go to sleep when you shut the car off? Otherwise, the USB port should charge.
      04-11-2011, 07:42 AM   #9
Ict528i
Drives: 2011 528i alpine white
I use a brand new nano and an iPhone 4. They definitely charge thru the console USB
      04-11-2011, 08:18 AM   #10
radarguy
Drives: 2024 M440ix, 2023 X3 M40ix
I don't have an i anything, but I use the center console USB for charging phones and other stuff compatible with USB. Jan 2011 build. I think I read where pre Sept 2010 builds may not have had enough power to charge things. Not sure about that.
      04-11-2011, 08:20 AM   #11
cliveywolves
United Kingdom
37
Yeah its always worked 100% ok for me too, my F10 is a August 2010 build
      04-13-2011, 11:08 AM   #12
raccoonraccoon
has anyone seen if they can charge an ipad off this port?
      04-13-2011, 11:12 AM   #13
cliveywolves
United Kingdom
37
Nope not tried my ipad yet, might have a look later...
      04-13-2011, 12:07 PM   #14
Autojack
Autojack's Avatar
Drives: 2011 550i Carbon Black M-Sport
My center console inputs charge my 2 year old ipod classic and also my Blackberry bold 9650. I have not tried it with an Iphone or an ipad.
I have a Sept 2010 build 2011 F10 550i
      04-16-2011, 02:55 PM   #15
paultantk
paultantk's Avatar
Drives: BMW 520d
2011 BMW 520d  [0.00]
I had this problem. Turns out it was a cheap cable that didn't have all the pins wired. Used an original cable and charges fine.
      04-17-2011, 12:26 AM   #16
konasunset
registered
konasunset's Avatar
Drives: 535i titanium silvr 1/11 build
What generation Nano do you have? I found that my Nano Gen 2 does not connect but my Classic does.
      04-17-2011, 07:48 AM   #17
Ict528i
It will not charge the iPad.
      03-15-2012, 08:18 AM   #18
fat dog
fat dog's Avatar
England
29
Drives: iX3 M Sport Pro
I have a Feb 2012 build F11 and bought an Ipod Classic 7th generation (very latest model) to use with the USB socket in the centre armrest. Although it works fine with the BMW sound system, it doesn't seem to charge. I am using the official/genuine ipod cable that came with my ipod.
Any thought or recommendations?
      03-15-2012, 10:30 AM   #19
jedpause
jedpause's Avatar
United Kingdom
158
Drives: G20 330e M Sport '21
Red face
fat_dog... I have the same iPod 160GB, and a Jan 12 car (MY 12/2011). Charges fine.
Suggest you reboot iPod (Menu and centre button hold until apple logo), and then reconnect cable to car and see.... sometimes it does not charge at first because first connection is a handshake and sometimes causes iPod to wobble (a bit like first time connecting to a PC for e.g.)
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud
Alpine White F10 M Sport - Gone to Stud
      03-16-2012, 02:47 AM   #20
martin mustang
Ireland
256
Drives: 640d,X5 45e, 911c4s, 635csi
I had the same problem with a nano plugged in my wife's X3, it was not stable on my 5 F10, so got her a classic with more storage.
Apple tends to change the connections often, try a different iPod if you can before working on the USB.
Tags
center console, ipod, usb port, won't charge
Search this Thread:
Advanced Search
5post
