Service reset DIY
03-13-2007, 04:21 AM | #1 |
83
Rep 1,557
Service reset DIY
Guys I looked everywhere (maybee not hard enough ) for a DIY service reset for E90 but couldn`t find one. So decided to try the E60 DIY which wasn`t too far off. I realise most cars are still under warranty but I will use this to replace my own brake pads and microfilter instead of being fleeced by the $tealers.
Step 1 Insert key into slot Step 2 Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear. Step 3 Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again. Step 4 You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items. Step 5 When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done Step 6 You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit. Sorry if this a re-post guys but like I said I couldn`t find it anywhere. I accept no responsibility if you break your car, this is done at your own risk. |
03-13-2007, 07:50 AM | #3 |
548
Rep 6,563
admin-stickies this pls (if you have not already done so ) ...there was another thread on this but this thread seems to give more step by step detail. Thanks.:rocks:
under construction! |
04-08-2007, 11:12 AM | #9 |
302
Rep 1,928
Drives: had e90, 330i mystic blue
you are missing something, that menu is LOCK to unlock it, you need to go in the menu to option 19 and is going to said "lock on" and then "code 00" to find your code you have to add the last 5 digits of your VIN, my unlock code is 20 then you nove the "code 00" to "code 20" then that menu will have many options like oil temp, cabin temp, real speed, time that said how many hours you have driven and the last one said "RESET" that's the one that you click and it will reset your service
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
04-08-2007, 03:11 PM | #10 | |
Rep 119
04-08-2007, 03:41 PM | #11 |
254
Rep 8,338
great post
04-21-2007, 07:03 AM | #13 | |
83
Rep 1,557
I have no idea what you`re talking about, honestly As for the others follow the instr. carefully and it will work. A word of warning `tho if you don`t want to alter the date of next service, you`ll need to change the date in your car to the date when the last service was done. Otherwise the computer will aytomatically change the date to 2 yrs from todays date. (hope that makes sense) |
04-24-2007, 09:40 PM | #14 |
Rep 17
I can confirm this works perfectly, when you follow the instructions given.
I do have a question on the "next service date". My computer did change the next service to 2 years from now. Not a big deal, I service my car when I want to, I don't care about BMW's free service. But, could you explain again about changing the computer's date to fix the 2 year service thing? Thanks |
04-26-2007, 04:16 PM | #15 |
83
Rep 1,557
Nice, to set the "next service date" to a desired date, choose your date, deduct 2 years, then before you reset the service alter the date in your settings to that date.
05-03-2007, 09:23 PM | #17 |
Administrator
40712
Rep 21,238
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
06-15-2007, 01:51 AM | #18 |
83
Rep 1,557
**UPDATE**
The service indicators can still be reset even when the inspection symbol appears (car on a lift) All you have to do is insert key hit the start button and wait for the red car on a lift to disappear (about 10-15 secs) before holding down the trip reset button. |
07-19-2007, 08:35 AM | #19 | |
18
Rep 892
I just picked up my car yesterday, and I have that inspection symbol showing up, what does that mean? Can I reset that? |
08-29-2007, 01:53 PM | #22 |
30
Rep 210
