Help!
03-28-2011, 06:39 AM | #1 |
135
Rep 2,000
Drives: 2007 E92 335i; 2015 X5 50i
Help!
Help this poor sob out guys. I was doing an steering wheel swap this weekend. Turned out great except my new dct paddles werent shifting. So I started to fiddle with it. Last night, after getting the airbag out, I plugged the negative terminal back in. Got an airbag error. Expected. But now the airbag is in and the code isn't going away. What should I do??
Join Bimmer Alliance....
https://www.facebook.com/groups/511846452162411/ Become a BMW CCA member & reference my member# 451032 |
03-28-2011, 07:36 AM | #3 |
135
Rep 2,000
That's Boost3d. I'm a bit of a noob to the tuning world.
03-28-2011, 08:10 AM | #4 |
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
If you don't disconnect the battery when unplugging the airbag, you will trigger the warning. The warning will also stay on till it is coded off.
Are you familar with INPA? Do you have a coding cable? |
03-28-2011, 10:22 AM | #5 |
135
Rep 2,000
No I don't have a coding cable but I do know someone who does. More importantly, is the car ok to drive? I mean I'm not going to be going into limp mode with it giving a code am I?
-- Granted, i'm sure i'm boned if the I get into a collision... |
03-28-2011, 12:49 PM | #6 |
12
Rep 859
The car is fine to drive. Just clear the code when you get a chance and the light will go off.
2007 335i SG Coupe
2009 128i AW |
03-28-2011, 12:54 PM | #7 |
Mmmm torque
19
Rep 318
Drives: Like a Boss, hard and fast
OP, INPA can also clear the code. But bottom line is that you need to get your car hooked up to a computer to get the code cleared.
Monaco Blue E90 328i with Nav, Sport, Premium and Comfort Access packages, 6FL with iPod cable
SAE spec Depo with HIDs and HID fogs Depo AE replacement Album |
03-31-2011, 09:49 PM | #8 |
135
Rep 2,000
Ok, maybe a related problem.
So my Airbag warning light is still on. I got a friend who'd take care of that. However, my paddle shifters won't work still. I've tried hooking up 335i multifunction buttons (not my own) and the m3 buttons as well as put my old paddles back on. No luck. I think it happens to be a coding issue. Anyone know what code we need to reset to fix the issue? Come on guys, help me out. |
03-31-2011, 10:11 PM | #9 | |
164
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
04-01-2011, 12:30 AM | #10 |
135
Rep 2,000
Tried that. No luck. Original buttons not installed though. Maybe the original buttons are coded for my car?
04-04-2011, 06:24 AM | #11 |
No 55mph
1616
Rep 8,474
So you're saying you originally had paddles that worked, now after the steering wheel install, even your stock paddles don't work?
I would say that coding might be an issue going from your original paddles to the DCT, but if even your original paddles with original MF buttons don't work, I would venture that this is not a coding issue if you never coded the car to begin with to change anything (I realize you went in there to remove the error, but you never coded the car previous to that) Because your original setup doesn't work either - Software doesn't know what type wheel you have installed, so this sounds to be a wiring/hardware incompatibility problem. - not as if the steering wheel sends a signal to the computer stating 'Hey, I'm a M3 steering wheel' At 1st guess I would say that it has something to do with the integration of the Paddles and the Multifunction buttons - which may be different between the wheel types, but you state you put back your original style MF Buttons and Paddles and they still didn't work?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
