Possible to activate cruise control set speed in display?
03-23-2011, 10:36 PM | #1 |
Rep 22
Possible to activate cruise control set speed in display? - Yes it can be done!
I have just started coding my '06 E90 and was wondering if it is possible to code the set speed display for the cruise control to come up in the info. display when you activate it. I don't have the active cruise control but I know this is possible as I have driven a 2010 LCI without ACC that would display the set speed.
Thanks in advance for any assistance provided and hello to all who read from down under. Last edited by Moonstone; 03-30-2011 at 05:19 PM.. Reason: Indicate that issue has been resolved. |
03-23-2011, 11:35 PM | #2 |
14
Rep 328
Mine flashes on for a second when I set it, but it doesn't stay up the whole time? Is this what you are talking about?
03-23-2011, 11:46 PM | #3 |
Rep 22
No nothing on mine, that is what the LCI I drove did. It is really annoying not having any indication the cruise control has engaged. Cruise control works OK though. I asked my dealer if this was a fault with mine but was told only on the LCI's did it display the set speed for a second or so.
03-24-2011, 07:33 AM | #4 | |
555
Rep 1,244
Drives: 2013 F10 M5
03-25-2011, 12:39 PM | #5 | |
32
Rep 180
03-25-2011, 08:00 PM | #6 |
Rep 22
Good idea Toad335. Here is a copy of my TRC file if anyone more knowledgable than myself is interested in comparing. Thanks again.
M-Sport Pack | BMW Individual Paint - Moonstone | BMW 193 18" Wheels | BMW Individual Interior Trim - Anthracite Maple
gbmw3119.00 |
03-28-2011, 06:00 PM | #8 |
Rep 22
Here is my KOMBI.TRC file.
03-28-2011, 06:18 PM | #9 | |
68
Rep 1,026
I have a 325XI 2006 and I can see the speed in the cluster for 1-2 sec.
I tried to compare my KOMBI with yours but there is too much differences. Quote:
03-28-2011, 06:40 PM | #10 |
Rep 22
Thanks for that Woodpecka. I wanted to get hold of an '06 KOMBI file so I could compare myself, much appreciated.
03-28-2011, 07:27 PM | #11 |
Rep 22
I did a quick comparison in excel between woodpecka's and my KOMBI files. I haven't had a chance to look over it closely but hopefully will be able to pick up the necessary changes I need to enable the cruise control set speed display.
03-29-2011, 12:21 PM | #12 |
32
Rep 180
The one that stands out most to me is TEMPOMAT_SETZ_ANZ_DAUER, which translates to CRUISE CONTROL SET TIME. I've also seen dauer translate to delay, so I'm thinking this might be the length of time that is shows on the display.
Mine is set to wert_02, yours is wert_01. Others are TCM_ALIVE_MONITOR (yours nicht_aktiv, mine aktiv) and TCM_ID_MONITOR (yours nicht_aktiv, mine aktiv). Try TEMPOMAT_SETZ_ANZ_DAUER and let me know if that works. |
03-30-2011, 05:15 PM | #13 |
Rep 22
It works! I changed the following-
BC_2_ENABLE changed to aktiv BC_LIMIT_ENABLE changed to aktiv TEMPOMAT_SETZ_ANZ_DAUER changed to wert_2 I'm not sure if all three need to be changed, but comparing to woodpecka's file mine were different so decided to change then to see what changes there would be. When I have some more time I might try and isolate which one was required, probably as Toad335 suggested the TEMPOMAT_SETZ_ANZ_DAUER value. Thanks to you both for your help. Now to see if I can get the Welcome lights to work, the car is a May '06 so I think I might be in trouble as the FRM module might not be capable.
04-03-2011, 06:26 PM | #14 |
Rep 22
Just to confirm back regarding my last post, only the following line needs to be change-
04-03-2011, 06:37 PM | #15 |
62
Rep 1,452
Moonstone, can you please add it to the coding spreadsheet by filling out this form?
https://spreadsheets.google.com/view...dZU1E6MQ#gid=6 Thank you.
01-15-2019, 03:56 AM | #16 |
Rep 9
Hi everyone,
I will try to resurrect this post in 2019 I have retrofited Cruise Control in my 2005 e90 320d. One guy coded that feature to VO and now CC works as expected, but without any indication. My car has "low cluster". With NCS expert i tryied to change TEMPOMAT_SETZ_ANZ_DAUER value to wert_2 in kombi but without result. Is it even possible to add this feature to KOMBI for such an old car? What this ACC_AUSSTATTUNG do? It has 4 values from wert_01 to wert_04. Maybe i need to code other models as well (as i mentioned above CC works)? |
01-15-2019, 09:59 AM | #17 |
456
Rep 2,747
on four cylinder cars you can only have one-time CC speed display when CC initiated or changed
six cylinder cars have cc speed indicator around speedometer
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
02-15-2019, 12:50 AM | #18 | |
99
Rep 237
Try setting the value to wert_02 instead of 2.
02-19-2019, 06:13 AM | #20 |
196
Rep 291
Didn't work with me.. value is there in my trc file when I read it back, but nothing in display when activating the cruise control. ☹
I guess it's because I have a 'low Kombi' / instrument cluster which doesn't display this function. 😕 Last edited by P14kle; 02-19-2019 at 02:05 PM.. |
06-30-2020, 09:32 AM | #21 |
Rep 36
Tempomat_setz_anz_dauer
i have set TEMPOMAT_SETZ_ANZ_DAUER to 02 and tried, but without result.
when i read again from ncs expert its again on 01, it goes back to 01 itself, what am i doing wrong? what i have to do i really want the function to work to see what speed cruise is set on bmw e90 2005 |
12-23-2020, 08:36 AM | #22 |
Rep 17
Hi everyone!
I really need help about this subject. I have 320d 163ps 2005 model I tried everything but I couldnt do the set speed display for the cruise control to come up in the dashborad for 3 second when change speed I dont know maybe its not possible with my car because of kombi module? I changed codes: TEMPOMAT_SETZ_ANZ_DAUER wert_01 to wert_02 ACC_AUSSTATTUNG wert_04 to wert_01 ACC_ALIVE_ZAEHLER nicht_aktiv to aktiv ACC_ID_MONITOR nicht_aktiv to aktiv but its still not showing on dashboard |
