Coding Injectors?
03-23-2011, 09:12 AM | #1 |
12
Rep 859
Coding Injectors?
I'm still waiting on my cable in the mail. In the mean time, I'm curious if anyone has been able to code injectors yet?
2007 335i SG Coupe
2009 128i AW |
03-23-2011, 09:42 AM | #2 | |
555
Rep 1,244
Drives: 2013 F10 M5
If the DME has options for controlling the injectors in the coding, it might be possible but I kinda doubt it. |
03-23-2011, 09:56 AM | #3 |
12
Rep 859
New injectors have to be coded when they are replaced (or moved from cylinder to cylinder for that matter). The DME needs to be programmed for a long code that is written and barcoded on each injector. You can't just replaced them and be done with it. Rumor has it that BavTech is working on adding the feature, but at present only the dealer can do it.
2007 335i SG Coupe
2009 128i AW |
03-23-2011, 10:14 AM | #4 | |
555
Rep 1,244
Drives: 2013 F10 M5
INPA is the diagnostics tool used by the BMW factory, it's not very user friendly but quite powerful. DIS is the diagnostics tool used by the BMW dealerships, it's alot more user friendly and supports all diagnostics and service functions of the car. DIS requires a little more setup because it's runs a unix based OS. There's multiple threads on other BMW forums on setting up DIS in VMWare and making it work with a USB/OBD cable. |
03-23-2011, 10:28 AM | #5 | |
12
Rep 859
2007 335i SG Coupe
2009 128i AW |
03-23-2011, 10:39 AM | #6 |
555
Rep 1,244
Drives: 2013 F10 M5
Same here except mine's in the unix area (AIX, Solaris, Tru64 before HP killed it and it's predecessor Digital Unix), it's pretty easy to get setup since you'd have an understanding of networks and such.
03-10-2012, 06:29 AM | #8 |
36
Rep 306
Can N52 engines be coded as well, on what basis would i put the new values in INPA?
M.Etreby
F M double Grills, 19"313, Perf.Exhaust with dimisatips, RPI red scoops, K&N filter, LUX-H8 160, Aluminum strut bar, PBX, Perf. Suspension, F30 M-Perf. Brakes |
03-10-2012, 09:20 AM | #9 |
46
Rep 541
03-19-2012, 11:59 AM | #10 |
1904
Rep 13,088
I have read the car adapts to the new injectors
Within a couple of days and the only thing the coding does it give it a base flow rate, which the computer then tweeks to were it wants it anyway based on driving conditions fuel etc etc..
Well I read/played the DIY and I guess I'm wrong the mj coding wouldn't change. Last edited by ctuna; 03-19-2012 at 12:45 PM.. |
