The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Differential Oil
      03-21-2011, 11:44 AM   #1
Simtastic
Drives: BMW 325i 2006
Differential Oil
I bought a used 325i 2006 at 81k miles. No idea how the old owner maintained it. so I have plenty of work ahead.
I will change, Oil & Filter, Power Steering Fluid, Air Filter, Sparks, Coolant Fluid, Windshield Fluid, ATF (to be done later).
I want to know what to use as fluids for those above.
Differential Oil (other than BMW OEM, do you know of any decent brand? any specific info to look for?)
- Coolant Fluid (same question)
- Windshield Fluid
Regarding ATF, like everybody I've read both views, I'm leaning towards changing it at 81k miles specially that I feel a tiny little delay on the 1st to 2nd gear sometimes, it's a bit annoying. I've read that when you change the oil this delay will be gone. what do you think?
Any help would be appreciated.
      03-21-2011, 01:26 PM   #2
Turkeybaster115
74
Drives: 335I
change your ATF ASAP! rear diff= any synthetic 75w 90. redline, mobile 1 or royal purple.
      03-22-2011, 03:24 AM   #3
Simtastic
I will change it asap, although it's quite expensive. I asked and it's 39 $ a quart. & i need around 9.5 l :S.
for the differential the dealer said they use Motul 75w90, is this the best oil to use?
      03-22-2011, 04:53 PM   #4
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
Motul or RedLine 75w90 are both great fluids for the Diff.
Search around on here, there are other options for the AT fluid, and other vendors that sell it much cheaper.
      03-27-2011, 11:41 PM   #5
acdHQK713K
acdHQK713K's Avatar
Drives: Car
+1
Change the ATF. Mine was nasty. I used Mercon SP to replace the drained oil, and purchased the pan from the The CTSC.
I used royal purple in the rear diff. Been great for 20k miles.
      03-28-2011, 04:49 PM   #6
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
Originally Posted by Stangorang View Post
+1
Have you had the Mercon SP in for 20k?
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      03-28-2011, 04:53 PM   #7
acdHQK713K
acdHQK713K's Avatar
Drives: Car
Nope just about 300 miles. The RP in the diff has been there for about 20k miles.
There is really no reason to keep that ATF in for so long. Mercon SP is cheap (~$5/qt) and a new pan/filter is only $120.
      03-28-2011, 06:54 PM   #8
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
I'm in full agreement about the ATF. I'd just like to see a few more people trying out fluids other than LF6 before I jump in. Thanks for giving it a shot.
