Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > No Heat passenger side PLEASE READ...
      03-20-2011, 01:42 PM   #1
335i101
335i101's Avatar
Drives: 2008 E60 M5
Ok, I just want to say that I have researched this topic extensively but I still have some questions.
Vehicle: 2007 335i Coupe 08/06 build date has Dual climate and Auto.
Problem: Regardless of heat setting the passenger side blows cool air. Defrost, vent and footwell. (It is distributing the air properly, but always cool) so, I have eliminated FSR.
Driver footwell extremely hot (I can manually make adjustments so thus isn't huge but maybe a clue)
Antifreeze/coolant down a little of the past 4 months, no visible leaks. I also performed the electric water pump bleed procedure and was able to get some air out of the lines.
HEATER CONTROL VALVE/WATER VALVE: this has been frustrating as at first glance I thought that would've the problem. However, I can't find this piece under the hood (or online as a part to purchase). I have taken off intake and there is a piece with three hoses going to it but not a "electric harness.". It had a part number and that came back to A/C condenser. I am starting to think that this piece is electronic now or is on the other side of the firewall. Since I can't find it I have not been able to test if this is the problem.
Thermostat: I have read that these cars have electronic thermostat, which I can't find for the life of me!?!? Also,if it was thermostat wouldn't I always get heat on the passenger side??
Heater Core: No smell of anti-freeze, no wetness in passenger footwell, or misty windows.
So here are my "uneducated guesses"...
1) Heater core is half bad and not distributing het to passenger side (maybe that is why my feet get crazy hot as well)??
2) Heater control valve is bad, but hidden or else I am blind??
3) Flaps / actuator not working properly? Like I said if I push the air goes to vent etc...but maybe there is a damper or flap that sends hot air over to the passenger side?!?
I kind of doubt thermostat as it is only blowing cool air.
Heater Core: can it go half bad? Or half clogged??
Before I get 10 responses about knurl knob, YES it is at red and YES I have turned off the "snowflake"
Thanks for the help. I will include a pic or two of the closest thing I can find to a heater control valve/ water valve.
https://mail.google.com/mail/s/?view...1&disp=attd&zw
      03-22-2011, 11:59 PM   #2
335i101
335i101's Avatar
Drives: 2008 E60 M5
bumping myself....anyone....??
      03-27-2011, 04:34 PM   #3
335i101
335i101's Avatar
Drives: 2008 E60 M5
More info
Update. Still need help. Warmed up car. Lower radiator hose cool, upper is warm/hot.
So does that mean thermostat stuck?? Could it still be heater core?
Thanks
[QUOTE=335i101;9170701]Ok, I just want to say that I have researched this topic extensively but I still have some questions.
[url]https://mail.google.com/mail/s/?view=att
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2008 M5 with muffler delete-sold
2007 650i-sold
2008 335i-JB4, DP, Meth-sold
      03-27-2011, 05:19 PM   #4
Bartman619
25
Drives: Bimmer
if it's the heater core leak, you would get coolant steaming out of the vents inside the car and you would smell coolant.
      03-27-2011, 05:30 PM   #5
335i101
335i101's Avatar
Drives: 2008 E60 M5
Bartman,
Does that isolate the thermostat as the problem? I found a diy for waterpump and thermostat. Hoping I don't need to do both??
      03-29-2011, 08:20 PM   #6
335i101
335i101's Avatar
Drives: 2008 E60 M5
Brought it to a Indy to look at and he said it something electrically and it could take several hours to diagnose it...he still has the car... I have a cherry red four door focus loaner...
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      11-04-2011, 05:29 PM   #7
Kimmo-R
Drives: E91 330d -06
Have you found out the problem? Mine has the same thing and also tried almost everything. Now winter is coming and really hoping to solve this.
      11-07-2011, 04:09 PM   #8
rtgirard
1-5-3-6-2-4
Drives: Awaiting 2013 335xi -
I have a thread going on this, too. You describe a very similar set of symptoms. In my case, the dealer is replacing the heater core... that should be done this week (hopefully tomorrow) and I'll post an update.
/edit - i should add that there were no noticeable leaks from the core... the dealer says it was just plain clogged.
      11-07-2011, 04:34 PM   #9
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Did you scan your car for fault codes? If the car commands the flap motors to move and try don't, that will throw a fault. You probably will not get any alert on your dash or iDrive.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      11-07-2011, 06:14 PM   #10
335i101
335i101's Avatar
Drives: 2008 E60 M5
Never got the item fixed....I asked a mech., while I was in the shop for something else and he said eater core as well... I guess I am in denial....
(no heater core leaks/smells)
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      11-07-2011, 06:15 PM   #11
335i101
335i101's Avatar
Drives: 2008 E60 M5
Jb4 and obd2 both scan fine
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      11-11-2011, 08:57 PM   #12
335i101
335i101's Avatar
Drives: 2008 E60 M5
Bump.
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      11-14-2011, 01:08 PM   #13
rtgirard
1-5-3-6-2-4
The replacement heater core fixed my issue... I'm going to go out on a limb and suggest that for you, too. Sorry... good luck!
      11-14-2011, 07:40 PM   #14
335i101
335i101's Avatar
Drives: 2008 E60 M5
Did they show u labor/parts on receipt... I am not in warranty...I think part is 150 or so and labor was ridiculous 7 hours or something...
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      12-01-2011, 10:44 PM   #15
mskvarenina
mskvarenina's Avatar
9
Drives: 2007 328xi
After having my water pump repaired, I'm having the same problem. The mechanic says there is a problem deep in the dash with the stepper motor.
Dealer says 15 ours (at $130 hour), plus parts and "programming".
      12-02-2011, 07:33 AM   #16
rtgirard
1-5-3-6-2-4
PM sent in reply to yours.
In summary, they listed 2.7 hours of diagnostic labor in addition to claiming 82 labor units. I think a labor unit is 6 minutes (one tenth of an hour)... so they claimed almost 11 hours total as far as I can tell. Minus the diagnostic labor I suppose they could claim 8 hours.
      12-10-2011, 08:34 PM   #17
07328XIT
Drives: 2007 328XIT
Exclamation No heat passenger side (heater core)
The dealer told me the heater core is clogged, that is why the heat is not working well, especially on the passenger side. It only blows cold. Vehicle is an '07 328xit (wagon) ....40K miles.....Apparently it's a big job, they have to pull the entire front interior of the car out to get to it. I wonder if it's a poorly designed part... for it to fail so soon? The maintenence schedule for the drain and flush cooling system (per dealer) is 100K miles. I guess they use some long life coolant.... but the heater core it's self is clogging...or so it seems. The dealer says it's wear and tear....Mmmm...mmmm
      12-10-2011, 09:09 PM   #18
335i101
335i101's Avatar
Drives: 2008 E60 M5
I am pretty sure it is the heater core...anyone know if there is a way to connect to the lines and blast some coolant or something in there to unclog it without taking the whole dash apart?
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      01-14-2012, 07:49 PM   #19
F30Mo16
31
Drives: 2016 BMW 328i
Any update to this? I'm experiencing the same exact symptoms... I have had my thermostat and water pump replaced a few months back. Winter is here and I'm freezing my ass off lol
      01-14-2012, 09:02 PM   #20
335i101
335i101's Avatar
Drives: 2008 E60 M5
Yeah...I had the dealer do a back flush and it made it a "little" better not...160.00 dollars better though.
It is the heater core and the quote to have it fixed was 2k.
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      01-15-2012, 01:02 PM   #21
F30Mo16
31
Wow.. When you say a back flush what do you mean exactly?
And for 2k I rather ride around with a blanket lol screw that.. I live in florida our cold doesn't last long and isn't really considered real cold lol. Mid 30's will be bareable for 2k... I rather get the m3 front and rear bumper lol
      01-15-2012, 01:20 PM   #22
335i101
335i101's Avatar
Drives: 2008 E60 M5
They disconnect the coolant lines running into the heater core and blast air into it in hopes of unclogging it.
The heater core itself is about 150.00 its the labor that adds up....the whole dash get removed.
I have been searching for a DIY to remove the dash but I can't seem to find one.....the heat on my side of the car is good but the passengers side is cold.
U r in FL, stop yur complaining... I am WI!!!
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
