bmw assist error code
03-19-2011, 02:31 PM | #1 |
Dictator
31
Rep 77
Hey guys looked around on this thread, but could not find where anyone had removed the bmw assist error after replacing the stock head unit. Has anyone done this?
thanks Demetri Last edited by Meat'sG80; 03-19-2011 at 02:40 PM.. |
03-19-2011, 02:34 PM | #2 |
61
Rep 1,300
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K |
03-19-2011, 08:58 PM | #3 |
253
Rep 7,089
Drives: '06 AW 330xi
Did you replace your HU with an oem one?
If not then you broke your most loop and need to join it back together. |
06-14-2011, 02:21 PM | #4 | |
Rep 185
I just want to know if no one has figured this out or is it just not possible?? |
06-14-2011, 03:10 PM | #5 |
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
What error you getting? Sos error? If so you deactivate it by going into the tcum (bluetooth) module. I will confirm the lines when I get home.
02-20-2013, 05:09 PM | #6 |
22
Rep 133
Hi DESI4life10, do you know which lines need to be changed in the TCUM module to code out the SOS error? I recently replaced my faulty MOST HU with a newer non-MOST model, and as expected, I'm getting an SOS error warning. I don't use BMW Assist, etc. anymore, so the error is redundant.
How do I code this out? |
03-03-2013, 02:04 AM | #9 |
22
Rep 133
AZAJ, thanks for the info! I haven't checked here in a while, but I found out too on another forum that those were indeed the right values to set! Cheers!
04-07-2013, 09:28 PM | #10 | |
47
Rep 465
Hey, thanks for the information, I got rid of my SOS error as well. I was just wondering, does this disable the use of the SOS button? or can I still click it and connect to BMW assist?
