The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > BIG Problem Water Pump Help
      03-17-2011, 08:29 AM   #1
u2usual
u2usual's Avatar
60
Drives: E46 M3 & F80 M3
Okay so here is the deal, I have a 2007 E92 335I with 37k miles. I had to get the radiator changed out. So I got everything done and poured in new fluid trying to pump the air out of the system. Letting the air out through the screw by the coolant reservoir cap. Spent the whole day doing that but the heater doesn't blow hot air and after 20min the overheating indicator will turn on in yellow then in red. The car will go into limp mode. I started off by changing the thermostat, nothing. I ran the car on the scanner, and it seems like the water pump will not turn on through the system. Checked the connectors and we are getting two negatives and one positive feed. What could this be? Bad fuse or relay? Low battery power? Cut somewhere in the line? Any help would be appreciated. Thanks guys.
Romans 3:23
2002 BMW M3 Racecar
2017 BMW M3 F80
      03-17-2011, 08:37 AM   #2
u2usual
u2usual's Avatar
60
Also is there a fuse or relay for the water pump?
Romans 3:23
2002 BMW M3 Racecar
2017 BMW M3 F80
      03-17-2011, 08:43 AM   #3
Kevin@AKMotorwerk
Kevin@AKMotorwerk's Avatar
Drives: THE GUY YOU LOVE TO HATE
did you test the water pump itself? its common for them to go bad. i believe it has two negatives because it runs on two speeds and it also circulates after the car is shut off to cool the turbos.
      03-17-2011, 10:00 AM   #4
Bcube
Been there, wrecked that.
18
Drives: '07 E93 335i
It sounds like your system is full of air. There is a BMW procedure in the DIY section on how to vent the air out of the coolant system. I would start here first.
The Venting procedure will turn on your electric water pump. You will clearly hear it. That will tell you if you have a waterpump (no power/seized) issue right off.
-Brian
~199K miles. I -still- don't fear my 335i.
      03-17-2011, 10:01 AM   #5
Kevin@AKMotorwerk
i think the problem is his pump wont turn on, so the bleeding procedure won't work or do any good anyway
      03-17-2011, 03:16 PM   #6
Bcube
18
Could be. Anytime someone starts a sentence with "I had to get the radiator changed out.", you know there is more to the story.
-Brian
      03-17-2011, 09:51 PM   #7
u2usual
u2usual's Avatar
60
Well it tuned out to be a bad circuit in the system. All fixed now.
Romans 3:23
2002 BMW M3 Racecar
2017 BMW M3 F80
      09-17-2012, 08:33 PM   #8
vallejoricky84
Drives: BMW 328i
I need your help
What is it exactly that you changed or fixed. I am having the same problem and would like to know if you could be more specific. If you would like to help just reply here or email me vallejoamen@aol.com I was about to change the water pump but this gave some hopes
      09-02-2015, 04:01 PM   #9
Alhaji igi
Drives: salon
Water pump failure
I just had an issue with my fan belt, when I changed it my car started over heating later I discover the water pump has failed. Pls help guys. What might have caused the problem..
