OEM Panic alarm not working after activated through coding
03-14-2011, 01:55 PM | #1 |
54
Rep 740
What issues can I trouble shoot to rectify this issue? My coder doesn't know what to do to resolve the panic button not working.
The coding he did was: Activate the alarm windows up park light delete Digital Speedo Power folding mirrors with remote Any advise would be appreciated. Last edited by 335TWNTURBO; 03-14-2011 at 02:14 PM.. |
03-14-2011, 01:58 PM | #2 | |
92
Rep 566
03-14-2011, 02:12 PM | #3 |
54
Rep 740
03-14-2011, 03:46 PM | #5 |
54
Rep 740
03-14-2011, 07:09 PM | #7 |
548
Rep 6,563
yup +1
under construction! |
03-17-2011, 03:22 PM | #9 |
201
Rep 3,328
Drives: Coding: Desi4life10@gmail.com
When you code the alarm, you can then specify in the cluster setting, if you want to sound the alarm and flash the lights when the car is locked or just have the lights flash etc.
I wonder if you also have to FA write to the kombie module as well |
03-24-2011, 02:09 PM | #11 |
54
Rep 740
03-24-2011, 02:51 PM | #12 |
555
Rep 1,244
Drives: 2013 F10 M5
How did your coder code the alarm? Did he just change the settings manually in the various modules? Did he add $302 to your VO and recode the whole car? Or did he add +K302 to your VO and recode the whole car?
Ideally, he should have added +K302 (it's the official VO code for a retrofitted alarm, $302 is if the car came with the alarm) to the VO and recode the whole car with a blank .MAN file. That will guarantee that all the settings were set to properly to the BMW defaults for the alarm in all required modules. |
03-24-2011, 03:46 PM | #13 | |
14
Rep 87
Drives: 2018 340i xDrive w/ M Sport
03-24-2011, 07:33 PM | #15 |
555
Rep 1,244
Drives: 2013 F10 M5
04-24-2011, 12:26 AM | #16 |
43
Rep 437
Drives: 2011 E92 335i AW
I think on top of all the other DWAS modules that you have to configure, you also have to configure the SONDERTASTE_PANIKALARM in the CAS module. Change value from "nicht_aktiv" to "panikalarm". SONDERTASTE it means special key (I assume this would activate our special-hold-down-trunk-button-for-5-seconds-key).
04-24-2011, 06:27 PM | #17 |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
^just recode with blank .man file and everything will write itself
04-24-2011, 06:30 PM | #18 |
43
Rep 437
04-25-2011, 01:34 AM | #19 | |
No 55mph
1619
Rep 8,476
That's why you always add to the V.O. BEFORE doing any seperate item coding....
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
04-25-2011, 12:23 PM | #20 |
SYTFU Crew
36
Rep 1,179
exactly. sorry didnt see the question or I would have answered that earlier.
05-12-2011, 03:56 AM | #21 | |
43
Rep 437
I still don't think my alarm is not fully activated. Alarm doesn't go off when I do the following: 1. windows rolled down, car locked (clown nose blinking), reach from outside and popped the hood. 2. car locked (clown nose blinking), windows up, rocked the rear part of the car by pulling up on the rear wheel-well area. What am I doing wrong? Or is the alarm not supposed to go off when I did those things? Thanks |
