Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > No A/C when Auto Pressed
      03-13-2011, 02:54 PM   #1
Toad335
32
Drives: LCI 335i
Thanks to el-drifot!
A/C will not automatically turn on when Auto is pressed.
Module: IHK
KLIMA_MIT_AUTO_0 -> nicht_aktiv
KLIMA_MIT_AUTO_1 -> nicht_aktiv
KLIMA_MIT_AUTO_10/15-> nicht_aktiv
KLIMA_MIT_AUTO_2 -> nicht_aktiv
      03-17-2011, 11:30 AM   #2
Nr!qUe
Nr!qUe's Avatar
Drives: 2009 E90 LCI 328i 6MT
interesting...
even though my AC is always on because of the humidity here.
2009 BMW E90 328i | Xenons | MT | Space Gray | Beige-ette | CF Fabric Trim | iPod/USB | 20% Tints | Euro-Plate | Rear Fog Switch Lego Mod | Painted Reflectors | Performance Short-shift Kit | Style 197 Wheels | OEM Sport Suspension |
      03-17-2011, 12:16 PM   #3
fisherbln
12
Drives: 2007 335i Coupe
OMG, this is enough to make me order a coding cable! This is one of the most annoying "features" on my car.
2007 335i SG Coupe
2009 128i AW
      03-25-2011, 09:32 AM   #4
dcorn
77
Drives: 2008 E90 335i
+1 I hate having to turn off A/C every time I turn on auto heat.
      03-29-2011, 07:08 PM   #5
Castel
Castel's Avatar
Drives: Tanzanite Blue '13 E92 M3
I switched it off with these variables. Works like a charm and the A/C stays off!
      04-05-2011, 09:30 AM   #6
Toad335
32
Drives: LCI 335i
Can anyone confirm that all four values need to be changed, or is it possible to change just one of these values? Not sure what all the numbers at the end indicate...
      04-05-2011, 11:24 AM   #7
mike-y
just another bmw douche bag
Drives: 1.9L of fury
also, is it possible to change the behavior of the recirculate button on the steering wheel? I'd rather have it turn the whole climate control system on and off, instead of just the recirculate function.
      04-05-2011, 11:37 AM   #8
Castel
Castel's Avatar
I changed all the values and it worked as expected, I didn't try changing just one. My guess is that each value for the A/C disable is for different conditions, like engine running, engine off, Climate control on... The only way to know for sure is to try each one and see what happens. I just changed all 4 and worked great .
