Please Help: Need DIY for DMTL replacement.
03-09-2011, 03:20 PM | #1 |
23
Rep 188
My check engine light came on yesterday, I spoke to my local shop & they told me to bring in the car. He ran a scan & told me that the DMTL was giving an error code.
He cleared the code & said to drive it around for a while, if it comes back up...then I need to replace the part. He is charging me $290.00 installed. I am confident that I can get the piece for somewhere around 150.00 here is a pic (# 2) : http://www.realoem.com/bmw/showparts...19&hg=16&fg=10 I need : 1) DIY so I can replace this part ANY help would be greatly appreciated. |
03-10-2011, 05:20 AM | #2 |
173
Rep 3,415
Just get the Bentley service manual from Amazon; it will have the procedure. If you are going to make repairs such as this, then the Bentley manual will be a good investment for you.
It's not too hard I'd guess. The pump is easily accessable once you remove the right-rear valence panel. dfriller probably could walk you through it. He's familiar with that system. |
03-10-2011, 10:02 AM | #3 | |
23
Rep 188
03-10-2011, 10:19 AM | #4 |
253
Rep 7,089
Drives: '06 AW 330xi
Just remove the panel under the passenger side bumper....about 8 screws i think, 8mm and 10mm.
Then I think it's 3 or 4 screws for the carbon canister. Im not even sure you need to remove the canister to access the pump. The hoses are held on by clips. Squeeze the connectors and wiggle them off. Then remove the pump. Not sure how that's secured but once you remove the panel, everything is visible/self explanatory. I saw someone on e90fanatics awhile ago selling the pump from a e92 M3 for $90. It should fit your car as well....I was going to buy it. |
03-11-2011, 09:26 AM | #5 | |
23
Rep 188
03-11-2011, 12:07 PM | #6 |
Rep 33
Remember though, that having a code for a DM-TL pump does not necessarily mean that the pump is the actual culprit. Could be a vacuum leak in the EVAP system (which the DM-TL pump is a part of).
03-04-2020, 05:42 AM | #11 |
Rep 29
Help me
So I have 3 codes P2401 P1429 P2419 I replaced my gas cap, canister and also DMTL. I also checked for wires and they're all good. I still have the 3 codes after running the car with my erased check engine. At this point In thinking of doing a smoke test but was wondering if anyone had any ideas? BMW E90 330i 06
Victor Ramirez
03-31-2020, 05:41 AM | #13 | |
17317
Rep 18,740
Smoke test is your best bet.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
Tags |
dmtl replacement |
