BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > turbo inlet manifold had got some play in it.
      03-08-2011, 02:18 PM   #1
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
My inlet manifold seems to be broken/or loose at the heat sheild spot. Anyone know if this a clamp that holds the pipe in place here?? Right where the #11 is pointing to is where the heat sheild is.
http://www.e90post.com/forums/showthread.php?t=39765
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
      03-09-2011, 07:21 PM   #2
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
more pic
someone please help!!! In part 1 where the heat sheilding is... thats where the pipe is flexing...
      03-09-2011, 11:57 PM   #3
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
v band was loose! this is two pieces, joined by a coupler. Hope I didn't slice it when i cut the heat shield.
      04-17-2011, 08:12 AM   #4
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
anyone know what part # 2 is??? Is it an oring, or gasket that seats between the turbo and the inlet tube??? I may have damaged it during fmic coupler install...
Any help is appreciated.
