The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > expansion tank floater broke and disappeared
      03-02-2011, 11:34 PM   #1
jlE90
17
Drives: 06 Jet Black E90
today i decided that i should check my coolant and found that it was pretty low, so i decided to put some coolant in there. i've notice that the floater didn't come up. so i start poking around in there and found it in the biggest chamber in the expansion tank. i cant seem to get it out and i kind of lost it now. should i be worry it would be lodge in my motor in the future?
thanks for any help and reply, i am scared to turn on my car.
      03-03-2011, 05:16 AM   #2
ENINTY
173
Drives: 2006 325i Sport
No worries to run your car. The floater can't get down the hose nor could it pass though the radiator. The only fix for it is a new coolant tank. The part is under $100, but I'm not sure of the labor cost to replace it. You'd have to drain the coolant. And independent BMW mechanic could make that repair for you. You don't need to take it to a dealer.
      03-03-2011, 01:26 PM   #3
jlE90
17
i am going to bimmerfest in may and i am about to drive my car from san francisco to pasadena. should i get this fix before i take the trip? its around a 400miles drive
      03-04-2011, 05:00 AM   #4
ENINTY
173
Get it fixed when you can. I'm sure it's been broken for a long time. There is no reason for it to be broken other than someone broke it at some point.
