BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 and HPFP
      03-02-2011, 10:02 PM   #1
ddc9999
Drives: bmw
N55 and HPFP
I know this is a topic that's probably been beat to dead, but I'm considering buying a 2011 BMW 335i Xdrive (which is a lot of money for me) and I want to ensure I'm not getting into trouble buying a car with a notorious HPFP.
I was wondering if any "recently" made 2011 x35s are having this issue. I read some stuff regarding 2011 HPFP problems but those were from posts around sept-nov 2010.
I heard that the N55 was supposed to fix the problem, but I also checked the BMW site and the recall on HPFPs that the N54 had doesn't apply to the N55. So if this car has problems, I'm gonna be on the hook for it.
I've researched this topic a lot, but as I said, this is a lot of money for me, and I want to make sure I get a car that reflects that. I figured I should get an up to date answer before going through with anything.
Thanks for you help!
And feel free to hit me with these:
      03-03-2011, 08:09 AM   #2
Slops
Slops's Avatar
South Africa
188
Drives: 2005 C55 AMG
its supposedly being fixed, but the real answer is that the engine is so new that it hasn't been tested enough by daily drivers to be sure. Even if it fails you are covered under the warranty anyway, no biggy.
      03-03-2011, 08:32 AM   #3
MJR63
MJR63's Avatar
Drives: 2011 335i X-Drive Sedan
I have 11,500 miles on my N55 and no problems! Yea!
      03-03-2011, 10:36 AM   #4
adrock
adrock's Avatar
Drives: 2014 435i
2011 E92 335i  [9.58]
2007 E92 335i  [0.00]
My car has ~2500 miles... Got a slow crank, and a half engine a few days ago, but no issues since then.... I hope it was just a fluke, but still, not normal for a car this new.
      03-03-2011, 11:19 AM   #5
ApexM3
ApexM3's Avatar
Drives: '16 M3
16 BMW M3  [0.00]
Well since you asked for it:
But the truth is, the N55 still uses the exact same HPFP and there have been cases of it failing already. I have the car you want to get and knock on wood, no problems so far.
You have to realize that if you do get the car it will come with a warranty so you will be covered. BMW still doesn't have an efficient HPFP replacement for the failed ones but im sure they will within the 3 years of your new car warranty
IMO.. get the car and know that it will be resolved at some point within your warranty.
Current: 2019 F90 M5 Competition
Previous: 2016 F80 M3
Past: 2013 E92 M3
Past: 2011 E92 335Xi
      03-03-2011, 05:12 PM   #6
Juiced46
74
Drives: 03 Turbo Cobra, 2011 335xi
I work for BMW and @ my dealer we have seen zero HPFP failures. However I have heard of a very few N55 HPFP failures. The N55 is using the same pumps that are going into the Recalled N54s. There is nothing different. Now should this change your mind on purchasing the car? No, absolutely not. The chances of the pump failing on you are going to be very slim. BMW still doesnt know if the new pumps are "the fix" they are to new and not enough miles on them to find out. But you are buying a brand new car, you arent going to be on the "hook" for anything. You will have a warranty, you will have nothing to worry about. Its not like you are going to be @ the dealer once a week getting the HPFP replaced. Alot of people blew the HPFP issue out of proportion. BMW has gotten ahold of the issue and it has been getting better. I wouldnt worry about it.
Plus Id hate to break it to you, no matter what brand car you buy, something is likely going to fail and you will end up @ the dealership getting it fixed.
      03-04-2011, 11:44 PM   #7
ddc9999
Drives: bmw
Thanks for all the help! I'm still undecided regarding the issue, but you all have shed a lot of light onto it for me.
      03-05-2011, 12:36 AM   #8
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
There have been maybe 2 cases at most regarding hpfp, and even those could have been something else.
I have over 20k miles 15k of those being tuned. Zero issues. Buy the car, you'll be happy you did.
ERnie
2016 BSM/f80/ZCP
      03-05-2011, 12:53 AM   #9
N55
N55's Avatar
Drives: 🚀
6300 miles 4000 of those miles tuned with Procede and no HPFP problems (Knocking on wood)
      03-05-2011, 07:21 AM   #10
Jalndrs
Drives: 2015 F15 35i
8200 on mine with 5k tuned. Good to go here. Go for it!
      03-05-2011, 08:00 AM   #11
cb4
cb4's Avatar
Drives: 2008 335xi
Get the 328 if reliability is important to you. You are sacrificing reliability for performance by going for the 335. The NA inline 6 is rock solid. The turbo, not so much.
      03-05-2011, 09:36 AM   #12
shockin330i
798
Drives: 2016 ZCP M3
Not so much as before. Of all the n55s here there have been about 2 cases and one was the own guys ault. he kept pushing thecar when it had no fuel.
ERnie
2016 BSM/f80/ZCP
      03-05-2011, 02:18 PM   #13
FrankiE90
FrankiE90's Avatar
Drives: Krooked Sk8board
my n55 just had the 15k service
- no fuel pump failure yet
had few random long cranks.
e90 is running strong
been very happy with the ride.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
      03-05-2011, 05:02 PM   #14
ddc9999
Drives: bmw
I'm definitly going to wait a bit to see if anything other problems start to surface. I'm planning on buying a new car come May or June.
I've driven the 328i xdrive before which blows my nissan altima away (obviously). I just test drove the 335i though and all I can say is holy f***.
      03-05-2011, 05:10 PM   #15
shockin330i
798
Drives: 2016 ZCP M3
Don't even bother in may or june. The new 3er will be coming out by then.
ERnie
2016 BSM/f80/ZCP
      03-05-2011, 06:25 PM   #16
ddc9999
Drives: bmw
Exactly.
I was going to see if they keep the same HPFP for 2012. Also, since I most likely will be get a used 2011 (let someone else take the 1st year depreciation hit) waiting till then kind of makes sense. Aren't the 2011 models cheaper once the 2012 ones comes out?
      03-11-2011, 10:09 AM   #17
grandmoff
Drives: 2011 e92 335i M-Sport 6MT
uggh, had to try 4 times to get my car started this morning. had a few of these at random the last week but today was the worst. once she is warm, no problems, fires right up. but when it is cold out in the morning she is starting to fight me. 1500 on the odo. no limp mode or anything at all once on the road, just having a tough time starting. really hoping it is a fluke.
      03-11-2011, 10:34 AM   #18
Slops
Slops's Avatar
South Africa
188
no good.. hope its just bad gas or something stupid
      03-11-2011, 11:26 AM   #19
sA x sKy
Sameet
sA x sKy's Avatar
Bangladesh
739
Drives: AY/B M4 '15
2015 BMW M4  [0.00]
Haven't had any problems at 1806 miles. *knock on wood*
      03-11-2011, 11:38 AM   #20
shockin330i
798
Drives: 2016 ZCP M3
20700 miles going strong
ERnie
2016 BSM/f80/ZCP
      03-11-2011, 12:08 PM   #21
grandmoff
You know, that is actually possible. This crap started right around my last fillup. I am going to try a different station today and see if things clear up! *crosses fingers*
      03-11-2011, 12:35 PM   #22
Slops
Slops's Avatar
South Africa
188
Fingers crossed!
I dont know if this was your case, but I've been told to never fill up while you see a tanker filling the tanks because that stirs up the shit at the bottom of the tank and your pump could be sucking it up and putting it into your car... dunno how much weight that carries but i guess its feasible.
Tags
hpfp, n55
Search this Thread:
Advanced Search
