Some jb4 big turbo dyno charts!
02-26-2011, 02:36 PM | #1 |
Joint Chiefs of Staff
4927
Rep 116,037
Just saw these customer dyno runs and thought they were worth sharing. Car is an automatic with full bolt ons, JB4, dual CM10 nozzles 95% meth, race gas (as insurance), and RB turbos. Even with the dual CM10 nozzles he is still fighting fueling problems up top. The 14.5psi run and 20psi run are targeting the same air/fuel curve but you can see at the higher boost level something just isn't keeping up. Possibly the in tank pump. Still not bad numbers. STD numbers were 1-2% lower.
Mike Last edited by Mike@N54Tuning.com; 02-26-2011 at 03:31 PM.. |
02-26-2011, 03:37 PM | #6 |
Professional Moose Racer
316
Rep 7,509
I'd take 500 hp.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
02-26-2011, 04:19 PM | #10 |
161
Rep 7,377
Nice results! Is there a reason why so little boost is pushed down low?
02-26-2011, 04:29 PM | #11 |
4927
Rep 116,037
02-26-2011, 04:36 PM | #13 |
Cpl D
38
Rep 563
07 AW e90 335 :jb4/dci/ic/meth= 12.2 @116 :jb4/dci/ic/meth/RaceGas/Slicks/gutted = Broken ET BOARD!
88- Mitsubishi Starion Turbo- Built~My feedback~ http://www.starquestclub.com/forum/i...0&fromsearch=1 |
02-26-2011, 04:49 PM | #16 |
161
Rep 7,377
Does it look blow up to you? Mine is holding pretty well to.
02-26-2011, 07:19 PM | #20 |
325
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
DAMN!
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
