Need Help With Brake Rotors!!!!
02-26-2011, 12:25 PM | #1 |
Elitehend26
Rep 5
I purchased drill slotted brake rotors for my BMW335I 2007 sports package E90, however they are a little bit smaller than my OEM brakes so the my mech was a little hessitant to install them and told me to verify that this big size difference is normal.. The rotors are specifically for my car but they are just a little smaller, is this normal with non-OEM parts for this car since its a sports packaged car?
02-26-2011, 01:23 PM | #2 |
90
Rep 2,707
Explain a little smaller? The pad generally extends all the way to the edge of the rotor. Which means if it was a little smaller the outer edge of the pad would not be a touching the rotors. I wouldn't even think about installing them.
zhpregistry.net - ZHP stats and free classifieds.
02-26-2011, 02:00 PM | #3 |
103
Rep 2,783
With brakes I wouldn't take chances, either get rotors that match-up or buy OEM.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
02-26-2011, 02:15 PM | #4 |
116
Rep 712
"Little smaller"?? Don't install them!! Get the RIGHT-sized rotors. I believe that those "little smaller" rotors are for 325i, 328i and 330i?? The 335i rotors are bigger.
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic. |
02-26-2011, 03:14 PM | #6 |
73
Rep 1,770
one time i did brakes, got the wrong part and the rear rotor was like an 1/8 of an inch too wide for the parking brake drum housing hub business and it seemed fine. Put it all on the car and the car would not move!
02-26-2011, 11:03 PM | #7 |
Moderator
618
Rep 10,858
We need more specific information to help you. That said, my initial response is wtf, how did you not get the right parts? Do not install different sized rotors.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
02-27-2011, 09:23 AM | #8 | |
88
Rep 1,404
Make sure you did not get the 135's 13.3" front (6 piston) or 12.8" rear rotors by mistake which are sized similar. When it comes to brake, don't play around and make sure you got the correct one. Don't take short cuts.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
