The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > cpo question on SES light which had TSB...
      02-25-2011, 10:34 AM   #1
MrDummy
→сяuisiиg iи му вмш←
MrDummy's Avatar
Drives: 2010 Space Gray 328i
2010 BMW 328i  [0.00]
Question cpo question on SES light which had TSB...
Hey guys,
I dropped car off at dealers for a p0128 code which involves thermostat, but when service advisor called me he said there was a TSB out for reprogramming the computer to fix it. If thats true, should i still have to pay for my $50 deductable when i get my car on monday?
Im getting other stuff done thats not warranty so that pricing is fine.
Thanks for any help...
MrD
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i
ProGaMeR on the XboX 360
      02-25-2011, 01:04 PM   #2
MrDummy
MrDummy's Avatar
PS
The other work i brought up, which i think is an ok deal, was to have my swaybar bushings replaced with new hardware(whatever that means) for a total, after a 15% off coupon was $215 plus tax. Is that a decent price?
Thanks
      02-27-2011, 09:52 AM   #3
MrDummy
MrDummy's Avatar
The more I searched this site the more upset I am getting in regards to finding any information on the CPO deductable for a TSB released that is supposed to fix & clear my SES P0128 code I had.
Anyone on here that can give me some decent advice on what to do???
Well since its Sunday and I need to get my car tomorrow and wanted to know what I should do in regards to the above issue.
After 60+ views I was hoping someone could help me out...
      02-27-2011, 10:07 AM   #4
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
P0128 means your thermostat failed in the open position...which is the way it's designed to fail. However it could also be tripped by a fault intake air temp or coolant temp sensor.
You always have to pay the deductible under cpo. I had to pay the deductible when I had my engine head replaced under the valve lifter tick TSB.
Can you get a copy of that tsb and post it here? I'm interested in this TSB since we have similar engines.
      02-27-2011, 11:29 AM   #5
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
its your deductable...you bring the car in...you pay the deductable?
      02-27-2011, 02:17 PM   #6
ceb
NHTSA Nazi
28
Drives: 335ix
A TSB merely tells the dealership how to fix a common issue. At the bottom of the TSB is the billing info for the dealer to submit. It is separated into two sections; under warranty and not under warranty. If there is nothing listed under "non-warranty" then your deductible applies.
      02-27-2011, 02:51 PM   #7
MrDummy
MrDummy's Avatar
Thanks guys and i will try to get the tsb
      03-03-2011, 12:02 PM   #8
MrDummy
MrDummy's Avatar
Here is ALL I got:
Reprogrammed DME Conrol Module / GWCode: 82456060 / Diag Code D1214_B0000000_90_212
If anyone can decypher that please post it...
      03-23-2011, 09:24 AM   #9
whip_lash
whip_lash's Avatar
16
Drives: '15 M3
This may be a dumb question but whats a TSB? something service bulletin? I have the P0128 code and i told the dealership i think its the thermostat and they said its not covered under the CPO warranty, should i just tell them the code and hopefully they can reprogram the comp to fix it?
      08-11-2011, 11:39 AM   #10
MrDummy
MrDummy's Avatar
BS it is covered under your CPO warranty and TSB = Technical Service Bulletin
