Newbie installed ****** Bov But not Blow off
02-24-2011, 05:58 PM | #1 |
E90 325I / E92 335I
22
Rep 155
Hi,
I just purchased a used ****** Bov Kit and i did installed today. But i don't know what happen for the bov cannot blow off. Here is the pictures and video that please let me know if i did something wrong. Thank You Small Caps for the factory diverter valves #1 [IMG]http://i577.photobucket.com/albums/ss216/noipip/BMW%20335i%20******%20Bov/IMG_2678.jpg[/IMG] Small Caps for the factory diverter valves #2 & the Chagre Pipe connection [IMG]http://i577.photobucket.com/albums/ss216/noipip/BMW%20335i%20******%20Bov/IMG_2674.jpg[/IMG] [IMG]http://i577.photobucket.com/albums/ss216/noipip/BMW%20335i%20******%20Bov/IMG_2675.jpg[/IMG] The hose in front of the bov connect to the Throttle body [IMG]http://i577.photobucket.com/albums/ss216/noipip/BMW%20335i%20******%20Bov/IMG_2676.jpg[/IMG] Throttle Body connections [IMG]http://i577.photobucket.com/albums/ss216/noipip/BMW%20335i%20******%20Bov/IMG_2677.jpg[/IMG] Here is the video for the sound. Here is the Video for testing the bov's air blow.. New Vaccum Connections from the back of the bov to the Intake Manifold. But tried after 5 mins, Check Engine Light comeup. I don't think it is correct connections. [IMG]http://i577.photobucket.com/albums/ss216/noipip/BMW%20335i%20******%20Bov/IMG_0342.jpg[/IMG] Thank You and please help. Last edited by noipip; 02-24-2011 at 11:45 PM.. |
02-24-2011, 06:08 PM | #2 |
7
Rep 238
Drives: F30 335i
it builds boost under load. let it warm up to op temp first,Drive it down the block, and if its making a WOOP WOOP WOOOP WOOP, its installed wrong, but it looks fine. I thought i did it wrong too until i took her for a spin.
02-24-2011, 07:02 PM | #4 |
93
Rep 1,794
02-24-2011, 08:33 PM | #6 |
7
Rep 238
Drives: F30 335i
let it warm up first, it keeps boost down til it gets to operating temp, those vids are of cars warmed up and mine only goes off when its reved high like 6-7 k, 5k it wont do it.
02-24-2011, 08:34 PM | #7 |
7
Rep 238
Drives: F30 335i
plus it sounds waaaayyyyy louder when your driving
02-24-2011, 09:22 PM | #8 |
165
Rep 2,875
False....you should still hear it when you rev it when it's NOT warmed up.....it just won't sound as loud. BOV will blow off whenever there's boost, whether it's stock boost or tuned boost......
Also, when idling, your BOV should be open and blowing out air. Put a piece of paper in front of the horn and see if it's blowing.....
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-24-2011, 09:45 PM | #10 |
7
Rep 238
Drives: F30 335i
yeah, I have an HKS SSQV, it doesnt open at idle by design. when the car is at idle, it doesnt build boost, it builds boost under load. if you have a boost gauge you can also see that when the car is cold, it wont build as much boost as it will when its warmed up.
02-24-2011, 10:06 PM | #12 |
E90 325I / E92 335I
22
Rep 155
Actualy I don't have any jb3/4 or any jb+ to boost my car. Everything under stock except dci. Is it I don't have too much boost on it? Or it just can blow louder when I go to 6k-7k? Thank you guys.
02-24-2011, 10:37 PM | #13 |
7
Rep 238
Drives: F30 335i
if its hooked up wrong you should atleast hear the turbo spool when reving, and then when you let go of the gas, you should hear compressor surge (which is bad). look up vids of compressor surge so you know what it sounds like, all you had to do was unplug the T vaccum splitter from the original Diverter valves and connect it to the BOV. At idle i have to rev it up to 6-7k rpms to hear it at all, but driving i just have to get on it a little bit. Even when im on stock map, it doesnt take much for it to open up.
02-24-2011, 10:43 PM | #14 |
92
Rep 252
if you purchased it 2nd hand and it was shipped, it's possible that the box was dropped in transit and the spring is jammed shut. slim chance, but I've seen it happen.
-2010 BMW 135i - Titanium Silver - Procede v3/ETS 5" IC/AR Catless DP>N54mid>Berk Race/BMS OCC/VRSF Turbo Inlets & CP/SP rotors/Pagid RS29/APEX ARC8/Ohlins DFV/M3 Full Suspension and Bushings/Wavetrac LSD // 395rwhp/469rwtq on 91oct
-2014 Toyota Sequoia Platinum - Overlander |
02-24-2011, 11:05 PM | #15 |
Some say...
239
Rep 4,296
Drives: Fresh
Just watched the video, there is def a very faint compressor surge sound when you let off, which is bad. Not a ton of boost on a stock set up so its not going to sounds like a supra's compressor surge.
First off let me start by saying you need to tidy up you connections to the IC piping, that is pretty lousy. 2. No, do not switch the hoses it is correctly installed. 3. Have you messed with the nut or screw on top of the BOV? If not take the valve off and see if you can open it with your fingers.
I have exhaust and an intake... |
02-24-2011, 11:08 PM | #16 |
E90 325I / E92 335I
22
Rep 155
Thx Ghines1279. But i am directly connected the vaccum line from the bov to the intake manifold. I didn't use the T Splitter to connect anything. And also i did drove my car for atleast 20mins. But still have no any sounds come up. The Seller sugest me to switch the Vaccum line to the back of the bov. And i was tried it for an 5 mins. The Check Engine light come up. WTF is going on.....?? Somebody knows?
Updated photos and video for testing the bov. Please help. |
02-24-2011, 11:10 PM | #17 | |
Some say...
239
Rep 4,296
Drives: Fresh
02-24-2011, 11:34 PM | #19 |
Some say...
239
Rep 4,296
Drives: Fresh
I think it is releasing pressure just a very minimal amount. If I were you I would take the valve off the chargepipe(2 allen key bolts) and see if you can push the valve down with your thumbs. You should be able to move it with some force but if it terribly difficult to move then either a) there is something defective with the BOV or b) the spring is too right so it takes too much force to make it open.
02-24-2011, 11:43 PM | #20 | |
E90 325I / E92 335I
22
Rep 155
Here is the link of the bov. |
02-25-2011, 01:37 AM | #21 |
Some say...
239
Rep 4,296
Drives: Fresh
What the hell? It is sucking air in?? I honestly am not sure of what is happening right here. The only thing I can think is the BOV is actually stuck open and the air being sucked in by the engine is creating vacuum so it pulls air in thru the BOV and then when you let off the butterfly on the throttle body closes creating internal pressure in the chargepipe b/c the turbos are still spooling and air blows out. If you look into the BOV where the air comes out, what does it look like? can you possibly get a picture of that?
02-25-2011, 03:53 AM | #22 |
47
Rep 693
The front of the BOV is suppose to get hooked up to stock vacuum line.
Your suppose to leave the rear DV in cap off the bottom of it and hook the rear vacuum line on BOV to the top of the stock DV. To be honest I bought this setup to try it out cause of the price. I like the chargepipe but the BOV sucks. Doesn't hold boost even when properly setup. I bought a synapse with the proper flange for this CP and now it works great. |
