Bio diesel
02-24-2011, 01:42 PM | #1 |
Rep 5
Bio diesel
I have a 335d saloon and wondered if I can run it on Bio Diesel, it’s says not to on the fuel cap but the boys from Top Gear managed it with an E46 330d. How hard can it be?
I’ve talked to an engineer who said it should be OK so long as you don’t let it sit in your tank for too long as it goes off. I use a tank a week so no problem there. Sorry if this has been up before I'm new to this. 335d lowered BBS CH |
02-24-2011, 01:55 PM | #2 |
268
Rep 9,915
Drives: VW T5
What percentage?
02-24-2011, 02:06 PM | #5 |
Rep 5
02-24-2011, 02:07 PM | #6 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Do not do it. Unless you like gummed up fuel delivery systems.
02-24-2011, 03:09 PM | #7 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
Sell the 335d and run a 306td and your crappy bio fuel!
Mate don't scrimp and scrape, you bought a 335d mate not a €500 shitter!!!
997.2 GT3
02-24-2011, 04:36 PM | #8 |
258
Rep 3,815
Biodiesel is corosive, in topgear it destroyed the fuel pump in matter of laps.
Morrisons use 5% mix of bio which is safe anything more you risk killing the engine as it will eat the system
F30 335i M Sport - now departed
02-25-2011, 02:26 PM | #10 |
Rep 5
335d is my idea of saving a few quid. I've traded down for an M3. But I just thought I could give Mr David Cameron a little less of my hard earned cash to blow on helicopters that don't fly and aircraft carriers with no planes. Anyway I guess that it's a none starter. Thanks for everyone’s input.
02-25-2011, 05:25 PM | #11 | |
290
Rep 2,598
02-26-2011, 09:45 AM | #12 |
172
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Doesn't the fuel filler flap state 'No bio diesel' or am I getting confused with my Mum's Octavia that defo. states that.
Either way, there will be good reason why you shouldn't use bio-diesel..........just little things like the cars fuel pump, fuel filters, associated filters and other gubbings are NOT designed to run on that 'stuff'. It also produces degrees of sludge that requires filters to deal with it. Anyhow, looks like you've now 'seen the light'. |
02-26-2011, 02:20 PM | #13 |
244
Rep 2,811
Drives: Jaguar XE P250 HSE
I noticed that Tesco diesel has 7% bio-diesel. I think that is the upper limit for BMW engines. As far as I am aware, all diesel has some proportion of bio-diesel in it nowadays.
02-26-2011, 02:43 PM | #14 |
58
Rep 2,398
02-26-2011, 07:21 PM | #15 |
Rep 127
The UK introduced the "Renewable Transport Fuel Obligation" in 2008, which required road fuels to contain 5% fuel from renewable sources by 2010 - i.e. biodiesel. This is similar to the EU biofuels directive 2003/30/EC. I believe the 5% is allowed within EN590 standard, but above that requires labelling at the pumps - I note that (even) BP Ultimate is labelled as "contains up to 7% biodiesel" up here.
Supposedly all modern diesel engines are fine on the 5% blend, but they are talking about properly refined biodiesel, not 5% used chip fat! I suspect the warnings on the filler cap are there because you can find 100% biodiesel pumps in the EU, and that will most likely eventually knacker the fuel pump and/or injectors. |
02-27-2011, 07:18 AM | #17 |
Rep 127
I think you'll find they're all the same now, perhaps with minor differences in labelling at the pumps: For example, this is Volkswagen's Biodiesel advice. EN590 (the diesel road fuel specification) was revised AGAIN in 2009 to allow 7% biofuel content. See the SMMT statement and the amendment to pump labelling legislation.
Confoozing, innit!? |
