AE Exhaust metallic vibration?
02-23-2011, 08:27 PM | #1 |
The Blue Beast
142
Rep 5,665
I just got my Autobahn Exotics installed today. I noticed that there is a loud metallic vibration sound when I am accelerating around 1800 rpm. Only around that range though. Is it suppose to be like that or was their a problem with the installation?
Cobb AP Stage 2+ | BMS DCI | UR Catless DP | UR Chargepipe | Tial BV 50mm | BSH OCC | ETS FMIC | Eisenmann Race Exhaust | KWv1 Coilovers | Volk TE37 TC Kline Ed. |
02-23-2011, 08:36 PM | #2 |
165
Rep 2,875
Check to see if the mid pipes are rubbing against the metal plate in the middle if the car.....maybe there's not enough clearance. I know when we installed my Vanguard, we had to put another couple washers to clear the pipes......
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-23-2011, 09:11 PM | #3 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Had the same issue with my TopSpeed exhaust.
02-23-2011, 09:13 PM | #5 |
422
Rep 8,003
02-24-2011, 08:10 AM | #6 |
156
Rep 3,730
Happened to my AE exhaust on first install too. Check your heat shields and that metal bracket, I eventually fixed the issue.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
02-24-2011, 08:16 AM | #7 |
The Blue Beast
142
Rep 5,665
What did you do to fix it? I was told to find where it was in contact and wrap a rag around it.
02-24-2011, 08:41 AM | #8 |
75
Rep 2,491
Drives: 991 C2S Guards Red
When I had my AE (which I dearly miss...) I had the same issue the first time I put it on. Just get the car up and push the head shields up and away as far as possible from the midpipes. The smallest touch will lead to a lot of vibration. The AE should not be giving you any issues because it is probably [one of, if not] the best fitting exhaust out there
991.1 C2S PDK, Guards Red | PDCC | Sport Chrono + | Clear Tail Lights | Alcantara Steering Wheel | HRE FF01 | TechArt Springs | Sport Exhaust
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK 997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded |
02-24-2011, 05:51 PM | #10 |
Well officer, what had happened was...
104
Rep 1,161
Drives: Grocery Getter
Having the same issue! Hoping to get it up on a lift this weekend and take a look at all of the things yous mentioned! Thanks! Will keep yous posted...
Old: BSM '09 E90 335i. PROcede Tuned & Modded | AW '13 F30 335i M Sport | AW '16 F36 428i xDrive M Sport Gran Coupe | AG '19 G05 x5 Individual
Current: IOMG '22 G80 M3C w/ go fast parts |
