Procede DIC 2/7 , catless Dp's..SES
02-23-2011, 04:51 PM | #1 |
7
Rep 178
My procede is installed and I'm running catless dp's, since the procede is supposed to have a dp fix hardwired why am I getting a SES light with canclear off?
I was running the 2/7 DIC maps and wanted to see if any CEL's came up, all that did was the two cat codes and another about running lean with no cats? I had not yet updated the harness to remove the DP fix so does anyone have ideas on why I'm getting the codes? Thanks a bunch! |
02-23-2011, 04:55 PM | #2 |
Rep 177
DP fix is by one of two methods. You either need to turn canclear on or adjust the O2 modifier value in to a lower percentage. 100% does nothing you may want to try 60%.
If you have an old software version Shiv has stated that canclear may not work properly in preventing SES light. But with most software versions the code (cat efficiency) will be cleard automatically before triggering an SES light if canclear is enabled. The preferred way is to turn canclear on. I have not heard of the hardwired DP fix that you mentioned. Perhaps there has been a change with new Procedes but this is how mine works. |
02-23-2011, 08:23 PM | #3 | |
165
Rep 2,875
You're probably referring to the harness update that frees up analog channels for sampling.....has nothing to do with DP SES light.......
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-23-2011, 11:56 PM | #4 | |
7
Rep 178
Yes, thats what I left out...I need to adjust the %. Thank you for reminding me..appreciate the feedback guys. Have a nice night.
