Chevron Techron (No need to Change Oil) unless...
02-22-2011, 12:45 PM | #1 |
103
Rep 2,783
There were some discussions on this board about changing the oil after using Chevron's fuel injector cleaner. I e-mailed Chevron and here is their answer:
Thank you for the inquiry. There is no need to change your vehicles oil after using the Techron Concentrate Plus (TCP). However, Chevron does recommend that you use no more than 5 treatments of the TCP per oil change. With the use of the TCP there is a concentration of the product in your gas tank which is at least 10 times higher than what is in the gasoline itself. This higher dosage might create the chance that some of the product will manage to get into the oil crankcase and react with certain oil additives therein or dilute the oil itself. This is the main reason for the limitation of use - customers would not want to "overdose" and cause an unsatisfactory amount of the product to be diluting the oil. The directions for use are such that any dilution that might occur would not be a problem. Again, It makes no difference if you add the Techron Concentrate before or after the oil change. Regards, Chevron Fuels Technical Services
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
02-22-2011, 02:02 PM | #2 |
1435
Rep 4,724
Cool! Makes me feel better!
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
02-22-2011, 02:57 PM | #3 |
165
Rep 7,433
Thanks for doing this
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
02-22-2011, 04:22 PM | #4 |
33
Rep 322
Thanks! Finally I can go add that bottle I bought thats sitting in the corner of my garage collecting dust.
Add Ons: Charcoal Filter Delete, K&N Drop-in, Air Scoops, HID Angel Eyes, Splitters, M3 Lip Spoiler, Gloss Black Kidney Grills, Blackvue DR500-GW, M-Tech rear, BMW Performance Exhaust, M3 control arms, Bilstein HD
02-25-2011, 07:27 AM | #7 |
1435
Rep 4,724
Yes.
02-25-2011, 08:32 AM | #9 |
103
Rep 2,783
LOL Not a genius, just an enthusiast, but thanks.
