BOV Question?
02-22-2011, 01:07 AM | #1 |
65
Rep 913
Drives: 2008 E92 335XI
BOV Question?
What's the best BOV I can buy for my 2008 335xi E92?
Matthew C. Friedberg
02-22-2011, 12:59 PM | #4 | |
33
Rep 494
We can also make special-order pipes for any valve if need be. |
02-22-2011, 02:51 PM | #6 |
165
Rep 2,875
It's all subjective.....there is no ONE best BOV as they all pretty much work the same. Except the first gen of AA BOV, as they use the older spring and diaphragm design in their horns (this was told to me by AA and HPF). because my AA BOV was leaking boost due to the valve not closing all the way. But that was from normal wear and tear more than anything, as I've had that for about 4 years on a tuned car.....
So I would suggest going with synapse or HKS......
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-22-2011, 06:23 PM | #7 |
The Blue Beast
142
Rep 5,665
I heard HKS SSQ has a lot of boost leak problems...
Cobb AP Stage 2+ | BMS DCI | UR Catless DP | UR Chargepipe | Tial BV 50mm | BSH OCC | ETS FMIC | Eisenmann Race Exhaust | KWv1 Coilovers | Volk TE37 TC Kline Ed. |
02-22-2011, 06:26 PM | #8 |
Some say...
239
Rep 4,296
Drives: Fresh
If you want your car to sound like rice, HKS FTW.
I have exhaust and an intake... |
02-22-2011, 06:30 PM | #9 |
COBB'ed
65
Rep 2,228
I'm quite satisfied with the synapse kit. Not super loud, but you can definitely hear it. Check it out:
13 Mini Cooper S 08 E92 335i (SOLD) |
02-22-2011, 06:32 PM | #10 |
Some say...
239
Rep 4,296
Drives: Fresh
^^I am the same way, I love my synapse. Great sound you can def hear but nothing obnoxious.
02-22-2011, 07:22 PM | #11 |
676
Rep 474
Drives: F36 440i GC
Do the stock DV's leak once you increase boost with a tune requiring you to add either a BOV or upgraded DV's? Or is the BOV added just for the sound? I'm assuming the DV's don't recirculate metered air, so replacing the DV's with a BOV doesn't cause the car to run rich?
I'm a noob when it comes to this on a BMW. I come from the world of DSM's.
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
02-22-2011, 10:53 PM | #12 |
56
Rep 1,224
sounds rice? dude it's a bov, high pitch or not, bov sounds sick no matter what
hks boost leak? they've been making bov's for years and majority of turbo cars use their bov....even the hpf e46 m3, im sure hpf wouldn't use a shit bov |
02-23-2011, 10:36 AM | #14 |
152
Rep 2,221
Check out our Blow Off Valves. They havent been marketed very much but they are great sounding, installation is really easy (they just snap in with our custom connectors). Here is the Install video so you can see how easy they are and how they sound.
02-23-2011, 10:45 AM | #15 |
92
Rep 1,465
I am personally a fan of DV's. I think a Blowoff Valve isn't meant for our cars. Also, a DV keeps the air into the engine which is how BMW designed the motor.
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
02-23-2011, 11:23 AM | #16 |
165
Rep 2,875
Face palm..........do your research..........DV or BOV doesn't matter on our car. The main diff is T-MAP vs MAF sensors and NOT just because our car 'came' with a DV bs..........
02-23-2011, 11:32 AM | #17 |
76
Rep 1,155
This is what I run on my personal car.
http://www.extremeturbosystems.com/B...duct_info.html You can't go wrong with a TiAL or Synapse blow off valve. They are both pull-type pistons so under vacuum they are slightly open and when in boost they are forced shut. This will insure that they won't leak under high boost. The TiAL using a diaphragm where the synapse doesn't. The videos from Synapse show the reaction time to be much quicker then a TiAL. In my opinion the TiAL is a better valve due to the diaphragm. Anytime you have heat and metal you have slight warping or variations, the diaphragm insures a proper seal. This is under extreme circumstances though. If you look at F1 and other cars makings over 1000hp they always use diaphragms to insure a proper seal. Good Luck! Michael |
02-23-2011, 01:35 PM | #20 |
24
Rep 666
Drives: 2007 BMW 335i
its all subjective man..... also use the search! you should know better...been here long enough..
Current: 07 e92 335i: JB4, AA Catless DP, Big Tom FMIC, CP-e Full Exhaust, Injen Intake, Type-S BOV, Meth
Previous: 03 Acura RSX-S: Boosted 400WHP (SOLD) |
02-23-2011, 09:39 PM | #21 |
COBB'ed
65
Rep 2,228
Got mine from these guys; http://www.e90post.com/forums/showthread.php?t=282120
02-23-2011, 11:35 PM | #22 |
65
Rep 913
WOW thanks guys!
