Mike/Terry, can you please join this discussion?
02-20-2011, 09:52 PM | #1 |
103
Rep 3,460
That is a bone stock car. How come the ecu did such a shitty job with the timing curve? If the ecu can't even support a stock boost car in those conditions what makes you think it could do anything with more boost? Here is a little quote from Terry himself Originally Posted by Terry335 Hi gang, I'm pretty sharp when it comes to tuning but somewhat of a n00b with regard to electrical engineering. I could use an experts help. Terry Tuner v1.0 has control of boost, but now I need to retard timing. My first idea was just to use a simple op-amp, relay, and resistor to crank up the IAT temperature when boost is over 8psi. This works, but has limitations and side effects. Mainly, it doesn't pull enough timing for our needs. So, I'm working on a more advanced concept. Offsetting the CPS signal. From May 2007: http://www.e90post.com/forums/showthread.php?t=63939 And in the same thread, May 2007: Quote: Originally Posted by Terry335 Bad idea to put timing in, we need to take it out to avoid knock under the higher boost level! Last edited by Clap135; 02-27-2011 at 07:20 PM.. |
02-20-2011, 09:56 PM | #2 |
103
Rep 3,460
02-20-2011, 09:59 PM | #3 |
///M Specialist South Shore BMW
777
Rep 7,110
subscribed. very interesting.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
02-20-2011, 10:01 PM | #4 |
12
Rep 490
Drives: 335i
wow good job clap!
btw I pm'd u something |
02-20-2011, 10:04 PM | #5 |
103
Rep 3,460
These arn't my logs guys, these were provided by Joshbody. I just thought they were a perfect example to exploit the bullshit fed to the community
02-20-2011, 10:13 PM | #6 |
103
Rep 3,460
A jb4 wont do shit with timing as it can't control it at all. It relies on the stock ecu to fix it, and from the above example, the stock ecu is not really fixing it on a stock car let alone a tuned car.
02-20-2011, 10:20 PM | #7 |
178
Rep 6,631
both the GIAC and Cobb flash tunes have rewritten ignition curves that suit the load targets. IMO, the Cobb flash has an overly conservative ignition curve (2 degrees down low, ramping to 10 degrees) however this is no different from any other Cobb OTS map from previous platforms. I have not seen any good GIAC stage 2 logs to comment on theirs.
The Procede uses CPS offsetting (crankshaft position sensor) to reduce the targeted curve by a number of degrees.
E90 LCI N54 6AT
02-20-2011, 10:20 PM | #8 |
103
Rep 3,460
Here is a log of my Cobb car
Cobb rewrites a lower timing curve into the car so it will not try to constantly climb and knock to the curve intended for a stock car Giac does the same Procede, offsets the timing curve and lowers it. Similar result to Giac/cobb, just done different. |
02-20-2011, 10:20 PM | #9 |
65
Rep 1,708
One of the arguments from some is that that some of the drops is vanos related. there is a decrease in timing due to vanos shift, but its gradual of about 2 to 3deg over 1000rpms or so. So none of the above sudden drops is due to vanos. i just wanted to clarify this early.
02-20-2011, 10:24 PM | #10 |
Custom Powder Coater
148
Rep 2,784
So is it knocking? Cobb would probably argue otherwise
02-20-2011, 10:24 PM | #11 |
65
Rep 1,708
Note about Cobb. These logs are during the winter when your hitting load targets with lower boost. Cobb will knock in the summer heat! All flashes will knock without Meth or super conservative table.
I really believe the procede has the best ignition timing currently when autotuning is enabled. |
02-20-2011, 10:24 PM | #12 |
178
Rep 6,631
I don't see any knock in the log Clap posted....
E90 LCI N54 6AT
02-20-2011, 10:25 PM | #13 |
103
Rep 3,460
No offense, to cobb, but they are simply wrong when it comes to timing drop outs...yes the logs in the first post are of a stock car knocking over and over and over and over again. Picture adding more boost to that and you do certainly ruin that engine.
02-20-2011, 10:25 PM | #14 | |
Joint Chiefs of Staff
4927
Rep 116,037
As far as what will happen tuned under worst case conditions such as shown here, 105 degree weather on 91 octane, the JB4 map5 will target close to stock boost levels with a much richer than stock air/fuel ratio. Which is exactly what one would want it to do. As I said in another thread I don't have a lot of hot weather logs to share but I did see this log from a PR customer helping capture bog data. He's on 93 octane and ambient temps were in the 90s. Timing is smooth as it should be. If there were to be a dip, and he were to be running the autotuniung map, then the tune would adjust itself to avoid it next run. Mike |
02-20-2011, 10:27 PM | #15 |
Rep 177
It would appear relying on the ECU to adjust timing even though boost is increased is rather unusual in the tuning world.
Clap: Do any other tunes take the JB approach?
2008 E90 335i | PROcede Rev 2.5 | PWM Meth | CP-E FMIC + OC | AR catless ceramic DP | BMS DCI | Wavetrac LSD | MORR MonoForged VS8.2 | Michelin PSS
02-20-2011, 10:28 PM | #16 | |
103
Rep 3,460
02-20-2011, 10:30 PM | #17 | |
103
Rep 3,460
02-20-2011, 10:31 PM | #18 |
148
Rep 2,784
I'll have to side with Cobb on this one
02-20-2011, 10:35 PM | #20 | |
65
Rep 1,708
02-20-2011, 10:37 PM | #21 | |
103
Rep 3,460
My procede logs are all under meth as well. The latest v5 stuff i tested for shiv had autotuning off and his 411whp map dropped timing on my car on extended pulls...meth was off cobb and the standback are the only tunes that I ran without meth. |
02-20-2011, 10:37 PM | #22 |
4927
Rep 116,037
