The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > How To: E90 LCI Facelift Style Tail Lights.
      02-20-2011, 05:31 PM   #1
chrismac
Addiction
chrismac's Avatar
39
Drives: BMW E91 M Sport Plus Edition
I was asked to create this, however I do not have step-by-step photos.
This guide will allow you to modify your tail lights to make them have the same style as the LCI facelift.
You will need:
Self adhesive red window tint film
Socket set
Flat head screw driver / trim tool
Ruler
Squidgy/credit card
Permanent pen/marker
Alcohol/Meths/degreaser
Empty fine spray bottle
Water
Washing up liquid
Blade/stanley knife
Scissors
Hairdryer
Guide
1] Remove your boot mounted tail lights by following the appropriate guide found here
2] Clean units with soapy water, dry, then wipe with Alcohol/Meths.
3] Cut 2 roughly sized sheets of the window tint film and offer them to the units.
4] You will need to cut a rectangular section out of the film so that the reverse light shines through. You can gauge the size whilst the film is offered to the unit. Mark the length and height of the section with a marker [on the removable film side].
5] Stick the 2 sheets together with tape so that you do not need to cut twice! Using your blade and a ruler cut your rectangular section out of the edge of the film.
6] Fill your spray bottle with water and a drop of washing up liquid and squirt the surface of the unit.
7] Offer the film to the unit and gently place in correct position, use your squidgy or credit card to swipe the water solution from centre outward.
8] Trim the around the edges of the film with your sharp blade, be very careful not to make contact with the unit.
9] Continue to swipe the water out to the edges, you will find that they may not stick down. This is where the hairdryer comes in. Blow the edges with hot air pushing them down until they stick.
10] Once done refit and admire!
Photos:
      02-20-2011, 06:00 PM   #2
bumere90
Grozniy
Drives: Carless
OP, where did you buy the red tint?
      02-20-2011, 06:03 PM   #3
chrismac
Addiction
chrismac's Avatar
39
I bought it from eBay. It is window tint film.
      02-20-2011, 07:05 PM   #4
Marcumac
Marcumac's Avatar
Drives: M235i
2014 BMW M235i  [0.00]
Nicely done! Definitely a nice alternative to Blacklines if you don't want to spend the money and like the red look.
      02-20-2011, 09:46 PM   #5
DimSum
202
Drives: SLOW
looks nice
      02-21-2011, 12:00 AM   #6
txusa03
550
Drives: TS330iPPSP6MT
nice, you have skills
under construction!
      02-21-2011, 05:33 AM   #7
Riaan335
South Africa
Drives: 2008 335i E90
Nice! thanks for the idea. Looks different.
Definitely gonna do mine as well!
      02-23-2011, 06:17 PM   #8
Sebastian_e90
SFGI4NT
Sebastian_e90's Avatar
33
Drives: Yes
2007 328i  [9.00]
Does the red tint match the outer light housing or did you tint both sections? Do you have any pictures of the car in reverse, does light only shine through the open section or the tint as well? Also, could you post a link to what tint you bought exactly, there's many options I see.
Sorry for all the questions, just have wanted to this for a while and was curious because I just may do it now. Thanks for the diy, looks great
      02-24-2011, 02:57 PM   #9
chrismac
Addiction
chrismac's Avatar
39
No, I just covered the white section. I have no issues with reversing [I have to do it every night up my unlit rural drive].
I dont have any pics of the reverse light in action however I can do so at some point [hard when your on your own!]
This is what I purchased:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_5060wt_1117
Thanks
      02-24-2011, 09:09 PM   #10
brilo
brilo's Avatar
Drives: 2007 328iT
Looks great, Ima do this!
      02-24-2011, 10:04 PM   #11
klove83
Drives: Red E90, Red E36 M3
I like it
      02-26-2011, 05:36 PM   #12
chrismac
Addiction
chrismac's Avatar
39
As requested a pic of the rear when dark and reverse selected:
And a new angle.
      03-02-2011, 02:54 PM   #13
Sebastian_e90
SFGI4NT
33
Drives: Yes
2007 328i  [9.00]
Thanks
Thanks for doing this Chris
      03-06-2011, 01:23 PM   #14
Westieracer
United Kingdom
Drives: E90 330i
I did my lights today following the DIY - excellent result and looks
Only thing I did different was at the end I finished off the film edges with a smooth file (used to do this when fitting window tints) to blend them into the edge of the light - will reduce the risk of them peeling.
Excellent DIY - thanks mate.
Dave.
      03-06-2011, 01:24 PM   #15
bumere90
Grozniy
Drives: Carless
Dave.
Dave, can you please some pictures?
-fatman
      03-06-2011, 01:53 PM   #16
Westieracer
United Kingdom
Drives: E90 330i
Yes, I plan to get the car out and wash tomorrow (weather permitting) I'll get a couple of pics posted up after...
Dave.
      03-07-2011, 04:06 PM   #17
Westieracer
United Kingdom
Drives: E90 330i
Couple of pics, excuse the poor quality the sun was quite bright for a change!
Dave.
      03-08-2011, 04:03 PM   #18
chrismac
Addiction
chrismac's Avatar
39
Good job! what file did you use?
      03-08-2011, 06:29 PM   #19
bumere90
Grozniy
Drives: Carless
looks fantastic, did you use the same material as OP did? the eBay stuff?
-fatman
      03-09-2011, 11:27 AM   #20
Westieracer
United Kingdom
Drives: E90 330i
Thanks for the DIY ! - file is about 4" long and fine grade. It's just abrasive enough to eat through the film and not go into the surface underneath. I just lightly file away from the centre of the job - iyswim.
bumere90 - yes the same material from ebay. It gives enough to do about 6 sets of lights. Plently spare if anybody close to me wants some....
      03-09-2011, 11:52 AM   #21
Westieracer
United Kingdom
Drives: E90 330i
Different view -
      03-14-2011, 05:57 AM   #22
mowflow
mowflow's Avatar
Scotland
62
Drives: Golf 7R
Did this myself yesterday. Was my first time working with tint film found it a bit tricky, made an ar*e of the first attempt but got it second time. I cut the clear bits with angled ends to follow the lines of the tail light just like on the lci models.
I also added another step to the process that seemed to really help with eliminating air bubbles (I've still got 1 or 2 mind). Between steps 5 and 6 I sprayed the light unit and put the film on with the backing still on and heated it with the hair dryer while kind of shaping it to the light with my fingers. I then cleaned and dried the unit and when applying the film sprayed the film rather than the unit. For some reason this worked better for me.
Some bad pictures taken in the rain to show the results.
