rejecting car
02-20-2011, 11:07 AM | #1 |
17
Rep 134
rejecting car
Been trying to do a search on rejecting a car to see if i stand any chance of rejecting mine, but every time the search only returns a 'FATAL ERROR' and no search results am i doing something wrong ?
02-20-2011, 11:18 AM | #2 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
What's up with the motor and the story about your experiance.
997.2 GT3
02-20-2011, 11:29 AM | #3 |
141
Rep 6,912
I'm guessing that using 'car' in the search topic throws up too many matches and hence the error.
E92 M3, Jerez Black, Fox Red Novillo, 19'' M Double Spoke, folding mirrors, lumbar support, front seat heating, PDC, USB, DAB, EDC, Bluetooth, Logic 7, High Gloss Shadowline, big smile
02-20-2011, 11:41 AM | #4 |
17
Rep 134
Didn't really want to post the full story, but had to have a new Turbo at 1700miles+ missing on cold idle, was told there was a 'Puma' saying a mod was req. to re route some pipes under the engine and that would cure the fault after waiting two weeks for the mod kit to be available and be fitted ,NO change been 'IN' various times for the fault to be found [can't find any fault] only does it on cold days! and for the first few miles
Had to take the car in and leave it overnight ,get a lift into dealers Sat morning to go out with a technician and point out the fault Car is about 6months old and has now only done 2600miles in total it was supposed to be my last expensive car ,retiring in less than 2years, a bit worried that when the warranty runs out it will only have done 15/18000miles maybe other possible faults will not have shown up by then ? ' |
02-20-2011, 11:58 AM | #5 |
268
Rep 9,915
Drives: VW T5
02-20-2011, 12:18 PM | #6 | |
6659
Rep 15,858
Has the garage asked what use it gets? HighlandPete |
02-20-2011, 12:30 PM | #7 |
32
Rep 549
I'm on the iPhone at the mo so can't do chapter and verse, but I did it with an AUC vehicle.
There's some threads on here and elsewhere I can link to when I'm back at the Mac. You really need a timeline or diary clearly recording all the issues. Did you buy on BMW finance? It may help if you did......
02-20-2011, 12:32 PM | #8 |
17
Rep 134
No soot or any other running problems, this is the 7th bmw diesel i have had in the past 7years [sounds silly when you write it down !] my driving has not changed in that time i do as much driving as i can at weekends and have been working 48hrs a week for some time not leaving much free driving time,I only live 2mies from work, but have had no problems with previous cars
02-20-2011, 12:51 PM | #9 | |
949
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
02-20-2011, 01:01 PM | #10 |
17
Rep 134
I don't think a turbo should go that quickly whatever the driving conditions , anyway i don't rev it when its cold or even that much when its warm [old git]
i've worked on diesel engines for 45years [plant] including turbos, the amount of misuse some of the plant gets is unbelievable but i've never seen a turbo go that soon ps i've not got BMW finance on my car Bob |
02-20-2011, 01:04 PM | #11 |
6659
Rep 15,858
I agree it shouldn't, but I've been around too long to rule anything out.
Depends why it was changed, may not of 'gone' as we understand it. But the misfire when cold... duff injector... too much soot. There are possibilities. HighlandPete |
02-20-2011, 01:16 PM | #12 |
17
Rep 134
The turbo was making police siren noises + engine ran like a tractor for the fist few minutes ,if an injector was faulty surely it wouldn't be limited to such a narrow range of conditions ? once the car had covered a mile or so the misfire went and it never occurred during driving or on the return trip even a number of hours later
Bob |
02-20-2011, 03:52 PM | #13 | |
6659
Rep 15,858
See why you are thinking of rejecting the car. HighlandPete |
02-21-2011, 12:41 PM | #14 |
17
Rep 134
No, Pete, starts are always fine,no missing or any problems, its only after being driven for about half a mile [coincides with my first set of traffic lights] after idling ok for the first thirty seconds or so it begins to miss,although i cant hear the engine actually miss a beat the engine intermittantly shakes as if its not firing evenly ,it only happens on cold days,freezing or just above and after another mile or so doesn't do it again
I think its a programming problem [engine management] it cant seem to decide what to do between being fully cold and starting to warm up ? Bob |
02-21-2011, 02:06 PM | #15 | |
32
Rep 549
Some info from my experience.....
http://www.e90post.com/forums/showth...light=rejected http://www.tz-uk.com/forum/viewtopic...hilit=rejected Quote:
02-21-2011, 02:23 PM | #16 | |
6659
Rep 15,858
HighlandPete |
02-21-2011, 03:24 PM | #17 |
37
Rep 408
Wouldn't be something like water in the fuel system?
When you fill up do you completely fill the tank? If not condensation can occur in the fuel tank if the vehicle is standing, other than that I'm out of ideas. |
02-22-2011, 03:05 AM | #18 |
54
Rep 2,197
It doesn't really matter what the cause of the fault is, fact is the owner has not had the car long, it's had major work done on it and it is still regularly in for repairs causing inconvenience and loss of confidence in the car and nobody knows what the real problem is.
Rejected. |
02-22-2011, 04:18 AM | #19 |
38
Rep 582
Whilst I am sure it is unrelated to your fault with covering less than 5k miles a year isnt that more trouble than good with a modern DPF fitted diesel? You'd have been better with a 325i surely?
02-22-2011, 12:12 PM | #20 |
17
Rep 134
Couldn't afford a 325i ,wouldn't really want one, i like the torque of the 320d nearly 300 ft ib is some mid range shove!
Dealer is now saying the problem could be a characteristic of the engine/car SPHEROIDS ! |
02-23-2011, 03:04 AM | #21 | |
Squadron Leader (Ret'd)
25
Rep 627
Something I did a few yeas back when I had a Peugot that had an intermittent problem with rough running was to record it on my dictaphone (shows how long ago!). Going into the garage and playing them a recording, they conceded there was a problem and were able to fix it. |
02-23-2011, 11:42 AM | #22 |
17
Rep 134
Bigest problem is that the fault only occurs on cold days around or not too much above freezing , so its not easy to replicate as its now getting warmer
