07 335i Spark Plug Change Thoughts
02-19-2011, 07:06 PM | #1 |
289
Rep 864
CBS - Says plugs good until 56k
. Dealer would not Change - minor skipping on cold starts . Ordered from bmwmercedesparts . Special Socket from ECStuning . The Lower Cowl and even the engine cover is heavy & a pain to remove . Plugs came out just like DIY Post -- thanks . Did not use anti seize -- my Bently did say use copper based - I forgot . Torqued at 23nm . All plugs looked ok except #3 looked a little oily -- others were dry and white deposits and definitely look worn --- prior engine skipping on cold starts -- no more . . With the engine cover off -- initial start up -- the valve tapping is loud -- guess that is why the cover is insulated. Made me wish for thicker oil . . Changing the wifes X5 3.0si plugs next w/e (65k). . GO TEAM |
02-20-2011, 08:37 PM | #3 |
Rep 86
Actually what you heard was not valve tapping but the piezo injectors ...HPFI is actually noisy
'07 335i Convertible - Karmesinrot/Korallrot, Dinan Stage 2, 6-speed, Sport/Premium/Cold Weather Pkgs., iDrive/Nav, BMWCCA#407025
'13 Ford F-150 XLT 4x4 - Ingot Silver/Gray, Ecoboost 3.5l Twin Turbo, 302A Equipment Group, 3.31 Electronic Lock Axle, 5Star 93 Perf./Tow tune '08 Mazda CX-9 Grand Touring - Crystal Pearl White/Tan |
02-21-2011, 11:01 AM | #4 |
12
Rep 859
+1. Anti-seize is not necessary.
2007 335i SG Coupe
2009 128i AW |
02-21-2011, 10:09 PM | #5 |
ghey
483
Rep 2,041
Per the Service/warranty guide it says to replace the spark plugs every 45,000 miles... Did you have yours done at 45k or are those the original ones?
02-22-2011, 06:45 PM | #6 |
289
Rep 864
45k Spark R&R
Well I thought the dealer would change but they said it was Condition Based and that the computer said it would be around 56k before they would need replacing. Similar to my rotors and pads. I do alot of highway driving so miles rack up with little wear.
. So I just orderd the parts myself -- this was the first replacement. |
03-07-2011, 02:16 PM | #8 |
121
Rep 1,568
Confirmed - dealer says I have another 10K to go, and I just passed 45K. Sucks, as there's no notification in our onboard service menu, so I assumed 45K.
03-08-2011, 11:57 AM | #9 | |
47
Rep 222
They even went as far as to tell me that my idrive has a little picture of a spark plug that tells me when I should bring it in for service. I told them that it doesn't and even welcomed them to sit in my car and find the little spark plug picture. They didn't take me up on my offer. In any case, I told them that the owner's manual gives an absolute statement to replace the spark plugs at 45k miles and that it doesn't say to replaced them at 45k miles or when the CBS says so. It says to replace at 45k miles. After some back and forth, they asked their warranty administrator and I guess that person agreed and so I brought my car in and had all six replaced. When I was there, they brought up the spark plug little picture again and he looked through the read data from my key and said, "oh, it looks like maybe your car doesn't have the little spark plug picture because it appears to be grouping the spark plug service with the oil change and filter service." '08 335 w/ 50600 miles. good luck.
'08 Montego Blue 335i, auto, grey leather, aluminum trim, 50% ceramic Llumar tint on all windows except windshield - all options except active steering, active cruise control, and HD radio
'01 Lexus IS300 - gone but not forgotten |
04-06-2011, 12:38 PM | #10 | |
20
Rep 244
05-01-2011, 04:16 PM | #11 |
48
Rep 1,038
05-02-2011, 12:42 PM | #12 |
121
Rep 1,568
^ it's most likely due to a SW update in the car. If they scan the key/vehicle, they can check maintenance countdown of your sparkplugs.
Also, 2007 model manuals show to change Spark plugs based on CBS. 2008+ based on 45K miles. |
05-02-2011, 03:05 PM | #13 |
133
Rep 4,764
I know I'm tuned, but if you own your car and want to keep it for a while, why not change them earlier? Mine looked heavily worn at 13,000 miles. Even though I have lots of mods I drive the car gently almost all the time.
After seeing how much the electrode had worn down compared to a new plug, I'm changing mine every 15k. |
05-02-2011, 08:06 PM | #14 |
19
Rep 284
I am planning on changing my plugs out soon, just got them in the mail today. Is it possible to reset the computer without iDrive. Not to mention this will help when I change my microfilter and brake fluid flush here soon.
335i E90 | BMS DCI | Black Matte Grill | JB4 | Logic 7 | Sport | Premium | Cold |
05-12-2011, 10:26 PM | #15 | |
48
Rep 1,038
09-08-2011, 12:34 PM | #17 |
47
Rep 222
I don't have access to my owner's manual at the moment but maybe check in the maintenance section. Keep in mind, my car is a 2008 and I've heard that various years have different "schedules." Just so you know though, my 2008 says to change the spark plugs every 45k miles. It's an absolute statement meaning it doesn't say to change it at 45k miles or when the CBS says to change it. It says change the spark plugs every 45k miles. Good luck.
09-08-2011, 12:59 PM | #19 | |
121
Rep 1,568
http://www.bmwusa.com/Standard/Conte...antyBooks.aspx Last edited by anerbe; 09-08-2011 at 01:30 PM.. Reason: wrong link |
09-08-2011, 01:26 PM | #20 | |
815
Rep 2,869
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
09-08-2011, 01:31 PM | #21 | |
121
Rep 1,568
you will not be covered past 4yr/50K, so take it in now. |
