water pump... change at 60k or wait?
02-17-2011, 01:52 AM | #1 |
Rep 17
i did some searching and was surprised to find out my 335i has a timing chain instead of a belt.
but what i'm not sure of is the water pump. on my family's s500 w/ a timing chain, the water pump isn't changed until it starts making noise/fails. is that the same for bmw's? or do i have to change it at 60k? |
02-17-2011, 02:41 AM | #2 |
33
Rep 812
I would change the water pump by 60k along with the thermostat. That is one of the weak points in all BMW cooling systems. It is better to be safe than sorry with preventative maintenance.
02-17-2011, 05:44 AM | #3 |
173
Rep 3,415
The water pump is electric and not driven by the engine belt system. The thermostat is separate from the engine block (it's actually mounted to the water pump). Being that the water pump is electrically driven, the failure of it is more related to production anomalities rather than wear. Waterpumps that are belt driven usually fail because the lateral pressure the belt exerts on the pump shaft eventually wear the seals and then bearings. Because the E90 water pump has no belt pressure as mentioned it will not fail for that reason. The only problem with this design is that you can't tell when the pump is starting to fail. Belt driven pumps have a weephole in them which provides indication that the inner shaft seal is starting to fail because it will allow a small amount of coolant to leak out for detection. If the E90 waterpump fails, it will show an engine overheating warning indictor in the gauges.
The thermostat fails open, so it won't overheat the engine if it does fail. Also, the thermostat operation is monitored by the OBDII system, and if not operating properly will trigger the "service engine soon" light. You should replace either one when they fail. They are not a "preventative maintenance" item. |
02-17-2011, 06:41 AM | #4 |
103
Rep 2,783
Read this, some last a long time, some others not so long. YMMV. http://www.e90post.com/forums/showth...er+pump&page=2
By the way, someone mentioned changing the timing belt if applicable. Well, it is not applicable for our cars. We have a chain and not a belt and NEVER heard of the chain failing even on cars with over 200,000 miles.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
02-17-2011, 09:05 AM | #5 |
173
Rep 3,415
So there is confusion going on here and in the other post cited. The OP is confusing different engine designs. A lot of Japanese cars and a lot of older European cars have an engine design using a toothed-rubber timing belt to drive the camshaft. Usually, this type of engine design utilizes the timing belt as mechanism to also drive the waterpump. Because waterpumps driven by belts tend to wear out over time, and because rubber timing belts, like all other engine drive belts, require replacement on a schedule as a preventative maintenance item, the best practice (and recommended by most manufacturers) is to replace the waterpump at the same interval as the timing belt. The concept being that since you are in that part of the engine changing the belt, it is economical sense to just replace the waterpump at the same time so as to prevent from going back in to just replace a failed waterpump at a later date. Timing belt driven water pumps are relatively inexpensive ($40 - $60) so the added cost to the job is minimal as compared to the labor to replace the waterpump at a later date.
The N52/54 design with a timing chain and electric water pump alleviate the need for replacement of the waterpump as it is not driven by the camshaft drive mechanism. The N52/54 waterpump is a $500 part and the Thermostat is a $120 part (not counting discounts), and obviously are not considered preventative maintenance items. |
02-17-2011, 09:22 AM | #6 |
Powered By 36DD
337
Rep 7,369
my car overheated.....at around 60k
bought the waterpump & thermostat at 20% discount.... had neighbor installed for $200.....
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
02-17-2011, 09:27 AM | #7 |
103
Rep 2,783
Curious, did you ever change the coolant before the water-pump failed?
02-17-2011, 01:56 PM | #8 | |
Rep 17
so the only time i'd really replace it is like the chain, if i start hearing noises/it breaks? |
02-17-2011, 06:24 PM | #9 | |
173
Rep 3,415
The other type of engine design is a camshaft drive that uses a metal chain called a timing chain (instead of the rubber belt). The timing chain is driven off of the crank shaft up to the camshaft. The timing chain is encased in a sealed cover on front of the engine and is bathed in engine oil for lubrication and cooling. Timing chains are very robust and unless there is a manufacturing defect in the chain, or the engine is really abused, they RARELY break. Timing chains are NOT a preventative maintenance item. Now what you are confused about is what type of engine design (timing belt or timing chain) also drives the water pump. On a traditional engine, if the engine has a timing belt, usually the timing belt is also used to drive the waterpump because it has to loop up around the camshaft (which is in the cylinderhead above the crank shaft) so it goes right by the waterpump pulley, so the engineers just drive the waterpump using the timing belt rather than the alternator belt. An engine that has a timing chain does not use the timing chain to drive the waterpump; the waterpump is driven using the alternator (i.e. serpentine) belt. In either design, the waterpump is mounted into a hole in the front of the engine block and is replaceable once the coolant is drained. Now onto the E90 engine. The N52 and N54 engines in the E90 use a waterpump that is directly driven by an electric motor (i.e. there is no belt used to drive the waterpump). Because it is a separate, electrically driven assembly, it can be mounted anywhere near the engine. BMW mounts it on the lower right side near the front of the engine just above the steering rack; it is not mounted in a hole in the engine block like a traditional waterpump. Because the electrically driven waterpump is not susceptible to the normal wear that a belt-driven waterpump is, it does not normally wear out (like a belt-driven waterpump) and need replacement. However, like any mechanical device it can break for unknown reasons and need replacement. If and when the thermostat fails is when you replace it. A failed thermostat on the E90 should not cause a breakdown, just an engine that is slow to warm up; so that is why it is not a preventative maintenance item. I hope this clears the subject up for you. |
02-17-2011, 06:37 PM | #10 | |
Powered By 36DD
337
Rep 7,369
been great since.....
02-25-2011, 06:13 PM | #11 | |
79
Rep 2,446
Not me. I am annoyed by the high cost but it is not much $ worse than cars that require a new timing belt + regular water pump + thermostat. |
02-25-2011, 06:38 PM | #12 | |
11
Rep 180
02-26-2011, 10:52 AM | #14 | |
124
Rep 5,627
So there is no way a BMW thermostat failure will leave you stranded on the side of the road!! It is not a preventative maintenance item, but if you want to do so, it costs over $500 at a dealer as it requires a coolant flush. Personally, I'll save my $$ for the ever increasing cost of 93 octane. Tom |
02-26-2011, 11:30 AM | #15 | ||
79
Rep 2,446
Actually I should have quoted this instead.
And if they are known to fail and the result is that you are left stranded, in my book, they automatically join the 'preventive maintenance' club. Turnersport agrees (although they are obviously biased); http://www.turnermotorsport.com/c-10...ter-pumps.aspx Referring to the electrical water pump; Quote:
02-26-2011, 02:28 PM | #16 |
124
Rep 5,627
I understand.
As both the OEM water pump and radiator were in fine shape when I traded my E46 after 10 years and 97,000 miles, I think I'd hold off on both until needed. But if you'll sleep better at night... Tom |
02-26-2011, 08:13 PM | #17 | |
173
Rep 3,415
02-27-2011, 10:14 AM | #18 |
253
Rep 7,089
Drives: '06 AW 330xi
You guys should also look into the oil filter housing gasket. The gasket is common failure point and when it deteriorates, chunks can clog the thermostat and/or damage the propeller in the water pump.
Changing the ofh gasket on our cars requires you to drain coolant as well though..... |
02-28-2011, 06:12 PM | #19 | |
79
Rep 2,446
In the first case, I agree with you (you don't have to bother I guess at 135K). In the second case, I prefer to pay upfront and avoid an emergency repair. 60K miles is probably a bit too early. the statistic is hard to assess. |
02-28-2011, 07:32 PM | #20 | |
79
Rep 2,446
Can somebody show an exploded view from realoem? I tried but could put my finger on. |
03-04-2011, 03:11 PM | #21 |
36
Rep 1,054
mine just went at 68K. CPO covered it! $50
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
