02-15-2011, 11:38 AM | #1 |
113
Rep 1,323
✚WHEELSTO | New Product Release - WORK Wheels Gnosis HS201 & HS201 Models
ZPost Members,
We are here to inform you guys about the New 2011 Release of the Work Wheels Gnosis HS201 a new addition to the Gnosis lineup with its 12 spoke design and the Gnosis HS202 with its unique curved mesh design. The Gnosis design concept focus on incorporating classic styling with bold and aggressive features, such as sharper spoke edges and all new redesigned lip flange. (finish shown above: Brush Silver Clear (BRU) Finish) The Gnosis HS201 features a thin 12 spoke design, perfectly suited to pair with any luxury sports coupe or sedan. This wheel is offered in a large range of sizing: 19x7.5 ~ 19x11.0 (Full Reverse) 20x8.0 ~ 20x11.0 (Full Reverse) 20x8.0 ~ 20x11.5 (Step Rim) 21x8.0 ~ 21x10.5 (Step Rim) Standard bolt patterns offered are 5x112, 5x114.3, and 5x120. Finishes available: Matte Deep Black (MDB) / Matte Silver (MSL) Wheels are built using 2 piece construction utilizing a low pressure cast center disk with spun forged barrel. Wheels are available in both Full Reverse barrel or Step Rim barrel. With the entire Gnosis lineup, this wheel utilizes the new redesigned lip flange. The new lip flange has a machined barrel finish along with a formed rim edge for added strength. Due to its two piece design, you can customize offsets within 1mm increments, allowing for fine tuning of wheel fitment. In addition, two piece wheels are stiffer and suitable for track use. As one can expect with WORK Wheels, there is a wide range of widths and customization options to choose from. (finish shown above: Brush Silver Clear (BRU) Finish) The Gnosis HS202 features a unique curved mesh design, which provides versatility to complement almost any vehicle. This wheel is available in 19" & 20" applications: 19x7.5 ~ 19x11.0 (Full Reverse) 20x8.0 ~ 20x11.5 (Step Rim). Standard bolt patterns offered are 5x112, 5x114.3, and 5x120. Finishes available: Matte Deep Black (MDB) / Matte Silver (MSL) Wheels are built using 2 piece construction utilizing a low pressure cast center disk with spun forged barrel. Wheels are available in both Full Reverse barrel or Step Rim barrel. With the entire Gnosis lineup, this wheel utilizes the new redesigned lip flange. The new lip flange has a machined barrel finish along with a formed rim edge for added strength. Due to its two piece design, you can customize offsets within 1mm increments, allowing for fine tuning of wheel fitment. In addition, two piece wheels are stiffer and suitable for track use. As one can expect with WORK Wheels, there is a wide range of widths and customization options to choose from. WheelSTO is an authorized dealer of Work Wheels. |
