JB4 and downpipes on map 0
02-13-2011, 10:51 PM | #1 |
Rep 3
Getting JB4 and downpipes. I know the JB4 takes care of any codes that will be triggered by having catless downpipes. My question is if I want or need to run on map 0 (bypass the tune or use BT tool), how do I work around the DME throwing a code for downpipes installed?
02-13-2011, 10:54 PM | #2 |
178
Rep 6,631
There is a stock map with CAN enabled (map 4) and one with CAN disabled (Map 0). I'm not sure if the DP fix is still enabled if you are running stock on the JB4. Worst case, you can buy the downpipe fix from Terry.
E90 LCI N54 6AT
02-14-2011, 06:50 AM | #3 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
