Just installed Vishnu Procede+Meth Kit, Need config help :)
02-13-2011, 07:11 PM | #1 |
Rep 4
N54, Procede V5 + Vishnu Meth Kit
Firmware: pro5v101 Initial Map: 12-17 6MT Changed Values: MAP1 Max Boost: 10, MAP2 Max Boost: 16, Injection Mode: 9 I have a few questions about the configuration settings. 2 things I need help with: 1) The meth flow value says at 4-5 when idling or under the meth controller engagement boost level, I checked the hose to the injector after the solenoid and there is no flow when at this level. So this 4-5 value really means 0. Is this normal? Do I need to change something? 2) The max flow I can get is 9 or 10. according to the following, the flow value should be 14. http://vishnutuningforum.com/viewtopic.php?f=3&t=13 Why am I not achieving full flow? ----------- What should I do to tune it and set it up correctly? Any help would be greatly appreciated. |
02-14-2011, 09:28 AM | #3 | |
Rep 4
I think you're right about the bad ground because i get often disconnects on the serial-pc port. -or that could be a different problem. |
