Identify the leak
02-13-2011, 01:16 PM | #1 |
48
Rep 842
Identify the leak
I have this strange and inconsistent leak coming from my car. Seems to be oil but I am n00b. It hardly leaks when I'm on a flat surface but it look like right as my car starts to back down the hill of my driveway it dumps a bunch of oil. Does that give any indicate of where my leak may be coming from and whether it is oil? I'll post pics very soon
http://img16.imageshack.us/i/img0484yo.jpg/ http://img69.imageshack.us/i/img0485m.jpg/ You can see in the second how as I start to back out it leaks more.
2006 325i: Matte Black Grills, AG m310 19's (19X8.5et35 & 19X9.5et33 - 235/35/19 & 265/30/19), Amber Covers, Magnaflow with black tips, Blacked Emblems, M3 Replica Bumper and Vorsteiner hood! |
02-13-2011, 03:54 PM | #2 |
25
Rep 701
try getting your car on a lift or jack it up in order to trace the leak. Looks like motor oil, but I could be wrong. check your oil level and power steering levels. check for leaks around your valve cover gasket and oil filter housing.
02-13-2011, 07:57 PM | #3 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
This. If it ain't motor oil it could be tranny fluid, there had been some reports of bad gaskets...
02-14-2011, 09:02 AM | #4 |
Rep 112
You need to get under the car and take off the plastic shielding to get a good look at where the leak is coming from (it's just a handful of screws), but if you wipe some fluid off the floor with a white paper towel and it has a red tint to it - it's transmission fluid. Transmission fluid is very thin. Motor oil will be thicker. From the looks of it I say tranny fluid. If it just starts "dumping" oil once the car is on an angle it may be a the fill plug on the rear of the transmission.
Check the easy fluids first - power steering and brake reservoirs under the hood. Monitor the fluid levels and make sure they don't move. Post an update when you know what the problem / solution is. |
