Vishnu Large and in Charge(pipe)
02-12-2011, 09:46 PM | #1 |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Tried my hand at fabrication today and built a fairly rough prototype charge pipe for our upcoming methanol injection kit. Not exactly rocket science but we settled on a big 3.25 inch aluminum thick walled tubing from the elbow all the way to the throttle body which is of the same diameter. This is to reduce the velocity of the air charge which gives more time for the methanol to atomize. We also went for the most gradual bend as possible, utilizing as much the available real-estate as possible. Under the charge pipe (not shown) is a bug for the Meth pump pressure switch. On the top are two jet adapters for the Aquamist jets. Our fabricator will be making 30 more this week. Including versions for the N55 which is identical minus the bypass valve flanges.
Show top to bottom: -Stock charge pipe with meth elbow -My old Riss Racing charge pipe (with some ahem... modifications) -Prototype Vishnu Large-and-in-Chargepipe with methanol mods Also in the process of getting the methanol kit brackets manufactured. Here is the bracket which holds the pump to the frame rail: Should have final production pics of the Meth kit + Charge pipe later this week. Cheers shiv Last edited by OpenFlash; 02-12-2011 at 09:53 PM.. |
02-12-2011, 09:52 PM | #3 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Cool. How much?
02-12-2011, 09:52 PM | #4 |
156
Rep 3,730
Looks good! Are you planning on adding the bolt-on bracket so it doesn't "blow off"?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
02-12-2011, 09:55 PM | #7 | |
1750
Rep 17,960
Drives: A Lot
Also, that mount that used to hold the charge pipe bracket will not be holding the methanol injector. Perfect location since the nozzles are only a few inches away which minimizes volume between the injector and the nozzles. Fast response! shiv |
02-12-2011, 10:31 PM | #10 |
Good life
130
Rep 1,937
noob question but I never understood what a upgraded charge pipe does or benefits?
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
02-12-2011, 10:41 PM | #12 | |
86
Rep 1,262
i want vrooooooopshhhhh
Josh-
02-12-2011, 10:41 PM | #13 |
549
Rep 7,705
This is awesome...time to put my upgraded turbos to good use with PROceed V5/New Meth kit! I even bought a laptop dedicated ONLY for PROceed use! good work Shivster!
02-12-2011, 10:51 PM | #15 |
273
Rep 5,876
someone needs to make an aluminum version of the intake manifold so I can run 6 injectors of my liking and eliminate what many think happen, cyl 6 meth starvation...on top of that I wouldn't have to worry about the plastic intake manifold cracking over time with higher boost pressures
02-12-2011, 11:03 PM | #16 | |
549
Rep 7,705
02-12-2011, 11:06 PM | #17 |
273
Rep 5,876
02-12-2011, 11:09 PM | #18 | |
86
Rep 1,262
Josh-
02-13-2011, 12:26 AM | #20 |
103
Rep 3,460
I like the boost source in the charge pipe, it will let manual meth users spray through the shift. I might have to pick this up from you if you make a Tial 50 flange for it.
