Leaking boost.......Videos inside.
02-10-2011, 01:22 AM | #1 |
164
Rep 2,875
Here see for yourselves.
The digital camera has crappy mic on it, so I'm not sure everyone can hear what I'm talking about...... Pay attention to my boost gauge (gas gauge), it's pegged at only 12psi going WOT from 3rd to 4th........
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-10-2011, 03:39 AM | #2 |
545
Rep 7,705
what could it be...i hate searching for boost leak!!! hope urs is something simple!
02-10-2011, 08:41 AM | #3 |
164
Rep 2,875
I'm not sure.....it's VERY frustrating to not have my car run right.....
Before the exhaust, I was pulling 15-16psi consistently. Now, only 12psi It's gotta be something in the exhaust connection. So that what led me to believe that it MIGHT be the gaskets......
02-10-2011, 09:00 AM | #4 |
111
Rep 1,043
i highly doubt the gaskets are leaking as you would not loose 2 psi if you had a small leake at the gasket area.
Check your CP and all the connections around the IC there there must be something wrong there, did you check your diverter valves? But then again what do i know Good luck
19 Audi RS5
15 Audi S5 GIAC Stage 2 white 11 E92 335is DCT FBO 441 whp silver 08 E92 335i FBO 6MT 427 whp space grey 05 E46 M3 red |
02-10-2011, 09:07 AM | #5 |
161
Rep 7,377
yeah try to do as well a REAL log
02-10-2011, 09:13 AM | #6 |
188
Rep 5,417
the only way you'll ever know if its a boost leak is to actually do a boost leak test with an good boos leak testing device. pressurize your system up to 20psi and use a squirt bottle with soapy water on your connections to check for bubbles - easiest most efficient way of getting your leak. Good luck!
02-10-2011, 10:02 AM | #7 | |
164
Rep 2,875
Dude you were right about the DV....I have AA bov and I just notices on the way to school today that the hissing is coming from there! So I'm assuming that the bov isn't closing all the way under WOT.....
If it is my bov, how can I fix it? I was thinking about changing my cp setup..... TIA Quote:
02-10-2011, 10:05 AM | #8 |
164
Rep 2,875
I did , but I sent it to Shiv a couple days ago. I didn't post because I don't know if it okay yet to post beta map results/datalog.....
I still have it saved, according to the log. I was only hitting 12.7psi at WOT....... I'll try to post that later as I think it's okay now to post things related to the DIC maps...... thanks for all your help guys!! Much appreciated.
02-10-2011, 10:11 AM | #9 | |
111
Rep 1,043
just put your stock CP back with the stock diverters shouldnt take longer then 20 - 30 minutes and run again this is what i would do.
19 Audi RS5
02-10-2011, 10:15 AM | #10 | ||
164
Rep 2,875
What's the point of doing that? Is it just to make sure that the leak was actually my bov?
I mean, I'm FBO, so I would like to stay ways from the stock cp and dv..... So besides that, is there any other way to fix it? Or do I just have to get a new cp with dv or bov? TIA Quote:
02-10-2011, 10:26 AM | #11 | |
111
Rep 1,043
19 Audi RS5
02-10-2011, 10:50 AM | #13 |
36
Rep 1,054
glad you found your leak.... I like to wire tie my DV's to stock charge pipe. I lace 2 ties together and it helps keep them from blowing out under 14+psi. I ran 19psi quite well this way but always lost some boost from the DV inlet hole around the edges. I found 1 psi instantly when I upgraded my charge pipe and turned the target down by 1psi and get the same performance, just less wastegate duty. Those damn connectors are hard to figure out... when the arrows are lined up it means they are locked in place.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
02-10-2011, 10:54 AM | #14 | |
Custom Powder Coater
147
Rep 2,784
02-10-2011, 10:59 AM | #15 |
147
Rep 2,784
Which in turn makes me wonder if recirculating the BOV/DV air back into the intake would cause slightly lower IAT's since the air that is being put back into the intakes has already gone thru the intercooler?
02-10-2011, 12:30 PM | #16 | ||
164
Rep 2,875
Yea it's hissing at WOT, and I'm well aware that the bov is open at idle. It's like hearing the engine sound and the turbos spools at low to mid rpms, but as soon as I go WOT, there's a loud hissing sound on top of the engine and turbo noise.....
I wish I had a better camera with a better mic.....it's really obvious when I'm in the car, even with windows up..... Quote:
02-10-2011, 01:23 PM | #17 |
164
Rep 2,875
Anyone know what the bet way to test for boost leaks on a BOV? meaning, checking to see if it closes all the way under full throttle?
Can I just rev my car in place and hold it at certain rpms and tell that way? Reason I ask is because HPF said the beat way to test for that is to strap my car on a dyno and see how it holds under full load.....is that really the only way? TIA
02-10-2011, 01:24 PM | #18 |
164
Rep 2,875
Also, do you guys know if the WG has anything to do with this loud hissing sound?
02-10-2011, 01:35 PM | #19 |
3441
Rep 79,211
As others said, just go back to stock diverter valves and see if the problem is fixed.
If the problem is fixed then you know your aftermarket part is defective. To fix it depends on whats wrong with it. It could be several things. You can run stock diverter valves with FBO, its not a big deal, you will still make the same power and everything. Also... If you get a log and post it up of your WG duty cycle that will explain everything. Along with boost RPM, TPS, ignition, ignition correction. Just to reiterate, go back to stock DV to see if the problem is fixed. Then contact AA to see how to fix the defective part or send it back. |
02-10-2011, 02:00 PM | #20 |
164
Rep 2,875
I just talked to AA amd they said that it can leak from the normal wear and tear. Also the BOV is still the spring and diaphragm setup, unlike the synapse or hks.....
Anyway, AA said if the BOV indeed is the culprit, then he can just sell me a BOV horn. Since I'm past the warranty they can't do much for me.... The horn itself is 275 according to AA......not including shipping. So I'm thinking if it's the bov, then I'll just switch my setup to Stett with meth bungs and synapse BOV or forged DVs.......
02-10-2011, 02:20 PM | #21 | |
147
Rep 2,784
02-10-2011, 02:32 PM | #22 |
164
Rep 2,875
^I think that's what I'm gonna do to see first. Before spending $125 or more at HPF for their time.....
