The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Possible differential noise
      02-09-2011, 04:54 PM   #1
hurricane56
hurricane56's Avatar
37
Drives: 2017 M3 ZCP
Hi all,
I was wondering if anyone has experienced the particular sound I'm hearing from my 2006 325xi. Whenever I'm cruising on the highway around 55-60 mph I start to hear a low frequency drone or hum. The noise actually starts to get quieter at 65-70 mph and higher. The problem is that it's very subtle, pretty much only noticeable when I'm on smooth pavement, a/c off, windows up. I was told by the local dealership that the sound was tread noise, but I've just recently had the tires changed and wheels balanced. I had a rear wheel bearing changed as well, but not sure if that has anything to do with the noise. Has anyone heard a sound like this before? Could this be my differentials or transfer case?
The reason I ask is that upon comparison with a slightly newer xdrive 3-series, the loaner car did not exhibit this noise. I'd appreciate any ideas you have.
      02-23-2011, 01:15 PM   #2
ghost_rider
Belgium
26
Drives: BMW e93 320i 2010 European
have the same problem i will inform you once a mechanic check it out
      02-23-2011, 01:30 PM   #3
hurricane56
37
Drives: 2017 M3 ZCP
thanks
      03-01-2011, 06:23 AM   #4
ghost_rider
Belgium
26
Found it its the differentisl bearings hopefully your problem will be much easier try when you close the windows to hear if the sound is coming from the middle of the car if not you have less to worry
      05-09-2011, 04:14 PM   #5
hurricane56
37
Drives: 2017 M3 ZCP
A quick update to this situation: I ended up going to a different dealership, since my the one closest to me would always dismiss my problem as described in the original post.
It took about three days of diagnosing the problem but my SA just called back indicating that the U-Joints in my drive shaft had somehow gone bad causing the humming sounds. A whole new drive shaft was ordered and will be installed tomorrow.
      05-10-2011, 11:40 AM   #6
06325sportsedan
Drives: 06 325i sedan sport package
i have the same problem in my rwd 325i changing tires didnt help either ill have the tranny out of mine in a few days to replace the second gear, i will also be checking u-joints now while the driveshaft is out thanx
      05-11-2011, 09:09 AM   #7
hurricane56
37
Drives: 2017 M3 ZCP
Be sure to check the center drive shaft bearing as well.
      08-28-2013, 07:15 PM   #8
535gtxenon
44
Drives: 535gt
sorry to dig up this old thread, but i am having the very similar situation, except mine is a 535xigt with N55 engine. the noise comes at 58mph, and seems disappear at 64mph. but the noise only comes if the gas paddle is stepped, if i lift from throttle, the noise disappear. so basically from 58mph to 64mph, step on the throttle, comes the noise, lift off, noise gone, the throttle is just like a switch for the noise at that particular speed range. by the way, my car is fairly new, only 6 months with 7k miles. any thoughts would be appreciated.
      11-13-2013, 12:18 AM   #9
amarth1972
amarth1972's Avatar
Drives: 08 BMW 328i Sedan
I had the same issue about 5000 miles after I bought my CPO 2008, I took it to the dealer and went with him on test drive, go on a quiet road and make sure to have them drive it in the speed range, this is a known issue but they have to hear it, my DS was replaced and never had issue again...
      11-13-2013, 11:25 PM   #10
Jo3_E90
Drives: BMW 335i
sorry to snick this old thread!... but im actually having a similar problem now and is driving me nuts.. i took the car to the BMW dealer to do an alliagment, since it was eating up one side of the tire, it end up taking forever since the (L/DRIVER wheel) apparently has a bad strut thats what it came out on the specification paper and this wheel couldn't be allege base on the BMW spec . i took the car to my mechanic this past weekend and with didn't see anything wrong with them, change the tire place right to left, i really need to do something with this i can't put new wheel and tires until i fix this first, any suggestion will be very helpful thank you!
      06-19-2018, 11:55 AM   #11
cburn
Drives: 2011 335I xDrive
2011 335XI  [0.00]
I'm also having this issue. Will post back when the dealer lets me know the damage.
      06-30-2018, 05:39 AM   #12
EffectOne
Drives: 2014 325d
I am having a similar problem. A whine or hum coming from the rear (ish). I suspected it was the bearings in the rear dif going.
I'll take my car to the local dealership and ask one of the mechanics to test drive it with me to identify the problem.
