Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > Bluetooth Retrofit Success
      01-30-2011, 10:58 PM   #1
Armito
Nai re!
Armito's Avatar
Greece
22
Drives: 2008 E90 M3 - Black
Thumbs up Bluetooth Retrofit Success
Just got my Bluetooth retrofit completed and wanted to share that installation went smoothly. I have a 2007 E92 335 that according to my dealer did not have BT preparation. My car other then the BT has all the options.
I installed the BT without installing the FZD. I just installed a TCU/Mic/BT antenna (Installing this week will work without it but your phone needs to be in back seat as I discovered today )
Final step was to get programming done as the BT was not part of the VO. I contacted Dimsum after reading favorable reviews on this board. He knows what he is doing and was able to program BT into the VO as well as program the TCU (and he was super quick and helpful). I also got some other items programmed and I have to say he knows his stuff.
I will add more information and pics this week of my install but just wanted to let you guys/gals know that if you have a wiring harness in your passengers side trunk with a most connector/White multipin connector/3 or 4 colored connectors then your good to go.
Cost around $500
Ari
      01-30-2011, 11:00 PM   #2
DimSum
202
Drives: SLOW
Cost around $500
Ari
      01-30-2011, 11:30 PM   #3
Want
YVR
Want's Avatar
22
Drives: A Monaco Blue
Sweet. 500 seems kinda justifiable. Pics and details!
I think I have a similar setup, just missing bluetooth. Subscribed!
mbmbmbmbmbmbmb
      01-30-2011, 11:53 PM   #4
Armito
Nai re!
Armito's Avatar
Greece
22
I will post detailed instructions on the hardware installation in the next couple of days
      01-31-2011, 01:18 AM   #5
Bavfan
7
Drives: 07 328i
Congrats! I'd like to see what prewire you need for this retrofit. I've got a 2007 E90 328i with sport, 6FL and PDC. Would like to see if I've got the prewire for BT.
      01-31-2011, 05:58 AM   #6
DimSum
202
Drives: SLOW
All cars before 2009 come pre-wired for Bluetooth. Same with wiring for the Alarm.
      01-31-2011, 08:14 AM   #7
yyzmike
Drives: 07 328i
Congrats on getting your BT up and running!! That's the first time I've heard of it going so smoothly.
Subscribing to hear all the details.
      01-31-2011, 08:32 AM   #8
BenTrovato
Driver
BenTrovato's Avatar
37
Drives: e92 335i
This is awesome, glad to hear someone got it done! Can't wait for the DIY
      01-31-2011, 10:58 AM   #9
marcvtec
407
Drives: M5
Cool, this will be a nice spring project
      01-31-2011, 11:04 AM   #10
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
This is awesome news. Props for tackling this.
+1 on DIMSUM service. I just got my car coded to know I have OEM xenons installed now. No need to trick the computer :-)
I wonder if I can do the blutooth retrofit with the mini cooper as well.
      01-31-2011, 01:07 PM   #11
rezadue
Two turbos are better than one!
rezadue's Avatar
119
Drives: 2017 BMW M4 ZCP
This is great. I am picking up an 08 335XI which does not have bluetooth.
any info on what part numbers, their cost and where you got them, as well as a writeup would be greatly appreciated.
      01-31-2011, 02:01 PM   #12
coco savage
coco savage's Avatar
Drives: BMW made them
ya, i have considered retrofitting some bluetooth in my ride....
      01-31-2011, 02:19 PM   #13
DimSum
202
Drives: SLOW
      01-31-2011, 07:36 PM   #14
jasonintoronto
33
Drives: 2007 335i coupe (sold)
ok i want to do this. what parts do i need. the part that always stopped me was the coding needed at the dealer. because dimsum can do this i'm in.
2007 Porsche Carrera 4
2007 BMW 335i Coupe (SOLD)
      01-31-2011, 09:36 PM   #15
DimSum
202
Drives: SLOW
Take a look at this thread:
http://www.e90post.com/forums/showthread.php?t=85149
Hunt around for parts, you can get them definitely for cheaper than what is listed on tisherBMW. As you can see here, http://www.e90post.com/forums/showthread.php?t=456687
Microphone and antenna can be bought at the dealer for less than $100.00
      02-01-2011, 02:32 PM   #16
jasonintoronto
33
ok thanks!
      02-02-2011, 01:13 AM   #17
Armito
Nai re!
Armito's Avatar
Greece
22
Here are some steps for the install:
1) Start off by seeing if you have Bluetooth wiring in your trunk. Remove the trunk liner (easily snaps off and look for the cables as per the picture below.
Picture of trunk wiring:
If you have the wiring as the picture shows above then you probably can proceed to next step. Remember I will explain installing the TCU not the MULF so please don't confuse it with that. Also my installation did not include the install of the FZD with SOS button as I don’t want to subscribe for the service. Addition of the FZD is possible but will add additional cost to the project.
First thing you will need to do is download the instructions from BMW: http://www.bmwtis.com/tsb/attachments/B841405_E9x.pdf
The parts you will need:
65 15 6 927 700 Bracket for Telematics Control x 1
84 50 6 928 461 Bluetooth Antenna x 1
84 31 6 938 762 Hands Free Telephone Microphone x 1
07 11 9 904 019 Hex Nut x 4 – This is a standard M5-8 Hex nut
84109171590 TCU Module - BMW Part # – ** Use this # in http://www.realoem.com it will bring up a list of other TCU part #'s that are newer/older. I believe both CDMA and GSM versions might work but to be on the safe side look for a GSM unit. The newer version the better. I installed a TCU from a salvage 2010 550i and part # was listed on Realoem.
Find a used part or search the salvage yards or buy new online
Follow instruction from 1-21 skip part 22 and continue from 23-28 with your existing FZD.
Picture of TCU installed with bracket:
To access the MOST connectors if you dont have fold down seats you need to remove your backseats. Use this thread to remove the backseats (Found from another thread) http://www.e90post.com/forums/showthread.php?t=4646.*
If you have fold down seats. Fold both seats down and remove the drivers side back side rest.
I have attached a pic from the 2 connectors seperated. The top connector is the spare most connector and the bottom the in-use cables. From the BMW instructions in Step 12 it says to remove 1 and 2 from upper block *** Caution these might not be the cable set from your most connector. To verify you are pulling correct set flash a light into the most connector in the trunk and see if the cables you removed light up. If they dont put back and try the other set as you may have more then one set. I had 2 sets and my wires were in position 1. Once you find the wires for your bluetooth from the top block its time to connect them to the bottom block. Again. In the instructions its says to move to position 2 as it assumes 1 set of wires. I had 3 sets of wires so I moved [Input 3-->4 and inserted input from upper block into 3 on lower block. Inserted Output from upper block into output 4 on lower block]
You basically want a completed loop. If you connect the loop and start your car and your cd-changer/sirius does not give any error message then you hooked it up in the loop correctly. Otherwise go back and try again.
Use this link for more on most loop: http://www.e90post.com/forums/showthread.php?t=376617
To remove the FZD and install the microphone remove the 2 sunvisors to the side and remove the inner clips that hold them on the inner side. This will allow you to put your hand in the headliner and push the FZD down. Do not try to remove as per BMW instructions it will not pop out. You need to go in from where the windshield and headliner meet. There are 2 metal clips in the front position of the FZD that hold it in place push those in and FZD will drop
You will see 2 mic spots. The empty slot had a dummy mic with the connector on it.
I have not included pictures of the bluetooth antenna install as I did not complete (Waiting for part). Bluetooth still works without it but your phone will need to be close to TCU.
Once all the hardware is installed and your connections are good the only error you will get is a SOS malfunction in your dash. At this point you need to get your car coded and this is where Dimsum did his magic . You will not see the bluetooth menu until you get it programmed. I have read that some people did not need programming and if this is the case for you great.
If you go to dealer for programming they probably wont be able to do it without FZD installation, so use Dimsum or someone else that can code the Bluetooth option in your VO.
      02-02-2011, 01:38 AM   #18
Bavfan
7
Drives: 07 328i
Thanks Armito for the doc! If mods are monitoring, I think it should go into DIY section.
      02-03-2011, 02:55 PM   #19
DimSum
202
Drives: SLOW
Thanks for the DIY Ari
      02-04-2011, 11:46 PM   #20
bmwstylexx
24
Drives: 2007 335i
what is the fzd?
      02-05-2011, 09:53 AM   #21
woodpecka
woodpecka's Avatar
68
Drives: E91
There is also this option. For 700$, you get much more!
http://www.e90post.com/forums/showthread.php?t=460657
      02-05-2011, 11:46 AM   #22
DimSum
202
Drives: SLOW
The interface looks so crap for that aftermarket unit.
