The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d Engine Problems
      01-24-2011, 06:04 AM   #1
dai_call_me_dave
Drives: 335xd F30 & X3 20d G01
Hi, I'm New to this Forum.
I bought a 335d about 6 wks ago, which up until Saturday was working fine. Now the engine has developed a strange problem.
When accelerating hard from stand still the car pulls hard in 1st 2nd 3rd gear but by the time the car is into 4th gear at about 80mph the power drops, it feels like there's no boost.
It's like the engine will only maintain boost for about 8 - 9 seconds.
The boost will come back if I’m not driving to aggressively.
There's no smoke or strange sounds, so I doubt’s there's anything wrong with the turbo's.
I took the liberty of attaching a web camera under the bonnet so I could see the actuator (of the large turbo) under different engine loads.
It appears that the actuator opens up fully at the same time as the boost drops off, this makes me think the ECU has decided to limit the boost? or could be a problem with the actuator control valve?
I’ll have a look later to see if the boost pipe has come loose.
No warning lights up.
I intend to get the DIS diagnostic package & cable so that I can monitor the boost. Can DIS datalog? It would be nice to see pedal position, engine speed, boost pressure etc while driving.
Any Ideas?
p.s. It's out of warranty.
      01-24-2011, 08:58 AM   #2
WilliamE92
WilliamE92's Avatar
21
Drives: 2013 EB F30 335 MT
Perhaps you're heatsoaking the stock intercooler with hard pulls, and its pulling boost to compensate?
      01-24-2011, 09:36 AM   #3
dai_call_me_dave
I doub't it as the outside temperature is only about 3 deg C, also the car is unmodified.
      01-24-2011, 01:20 PM   #4
dai_call_me_dave
Correction:
After looking through RealOEM diagrams I belive the actuator that I have observed via web cam is the connection valve between the two turbos and not the waste gate of the large turbo.
It appears there are three actautors, one for each turbo plus a cross connection.
I would love to know how this is set up, very complicated!
Does anyone know if the actuator extends to open the cross connection? or is it reverse acting?
      01-24-2011, 03:22 PM   #5
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
It might be a good idea to post this in the UK forum, there are many more "D" drivers there than in the U.S.. Good luck!
Tags
335d problem engine
Search this Thread:
Advanced Search
