Dynoed with N55 AR Downpipe before/after
01-23-2011, 09:23 AM | #1 |
74
Rep 1,035
Went to the dyno yesterday to see what type of gains I got with the N55 AR downpipe. The results were very surprising to say the least. Obviously this was not done on the same day which will affect results slightly.
Mods before AR DP: JB3 Beta Tune AMS 3" Catback Only thing added was the AR Downpipe from the previous dyno session. Also, dont mind on the graph where it says MAP 5, its MAP 1 as the JB3 for the N55 only has one MAP. Here are the results. Only a 3whp gain PEAK and a 9wtq loss. However as you can see the car picks up a good 10-25whp above 5500 RPMs, where as before it would fall, but it did nothing for peak #s. All in all, not depressed with the #s, but alittle surprised with the outcome. I absolutely love the sound, and the fact I have more power above 5500, I just wish it would have given more power across the board. IMO I think the 4" DP is just to large for this small of a turbo. I think a 3" or 3.5" (catless) would be perfect to get the TQ #s up and still be able to make more power up top without it falling. |
01-23-2011, 09:42 AM | #3 |
74
Rep 1,035
No, we did 3 pulls stock with catback, then 3 pulls with jb3 and catback, then 3 pulls with the jb3 , catback and dp. Pre dp #s were all within 5hp/tq of each other, first pull with the Ar dp was 281/315. I posted the best runs of each
01-23-2011, 11:07 AM | #6 |
151
Rep 1,809
So the N55 stock catalytic converter is not that restrictive. This can be good but mostly bad for squeezing the most power out of the engine...
01-23-2011, 11:16 AM | #7 |
52
Rep 811
I'm not surprised at all. It's pretty, but I didn't expect much at all. Running higher boost and meth with the stock downpipe and then the AR would likely show a more dramatic increase.
'08 TiAg E90 335 M-Aero kit. - SOLD
01-23-2011, 12:57 PM | #8 | |
295
Rep 4,408
01-23-2011, 01:16 PM | #10 | |||||
74
Rep 1,035
To put it into perspective for you. I run a 76mm turbo on my mustang (which dwarfs the turbo on the BMW). If it still had the 6spd in it, it would put down approx 900-950rwhp. I still run a 3" DP. I would benefit from a 4" DP alittle, I would sacrafice a little spool but I will pick up power up top, but peak TQ would drop. Ive tested this previously on a car with the same setup. Another example, on this same 76mm turbo. I used to run a .81 exhaust housing on the turbo. This setup produced 730rwhp/800rwtq. I wanted the .81 housing to help spool up, but power was dropping above 6000rpms. I then switched to a .96 housing on the turbo (bigger) The car still peaked 730rwhp, however I lost 100ftlbs which dropped me to 700rwtq, but the power falling off up top now held to 7000rpms instead of falling @ 6000. With the 4" DP on the N55 I think it is creating to much of a loss in backpressure causing the TQ #s to drop and not come on as hard. I think a 3-3.5" would be a happy medium. Quote:
How much more of adjustment are you guys doing on the N54 with DPs? More timing/af adjustments? AF compared to pre DP was very close in most of the pull, the biggest variance was .5 richer with the AR DP in a few spots compared to the stock DP, mainly above 5500rpms. |
01-23-2011, 04:15 PM | #12 |
19
Rep 267
Drives: 2007 E93 Alpine white with Red
Too bad you weren't running with a tune that autotunes. It would have been interesting to see what it could have squeezed out of it.
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
01-23-2011, 04:58 PM | #14 |
114
Rep 2,428
01-23-2011, 04:59 PM | #15 |
798
Rep 4,784
I have no idea, but its super gay. And not homosexual gay, but your parents are chaperoning your school dance gay.
Shiv had the same problem with his baseline...
ERnie
2016 BSM/f80/ZCP |
01-23-2011, 05:00 PM | #16 |
114
Rep 2,428
01-23-2011, 05:03 PM | #17 |
798
Rep 4,784
Stock no tune.
ERnie
2016 BSM/f80/ZCP |
01-23-2011, 05:05 PM | #19 |
114
Rep 2,428
Ok yeah I wasn't sure if your new car was an xi on a mustang or what the deal was...
Anyways, that seems very strange for a stock car to run that tq curve and that A/F ratio.... Are you able to feel that 50tq drop in power for all of the 3,000-4,000 range? |
01-23-2011, 05:15 PM | #20 | |
798
Rep 4,784
Here are my Procede map 1 runs. Car was literally on the dyno back to back to back runs. 93 exxon(which I'm coming to the conclusion that my car hates) Car hadn't fully adapted yet, at least I think...
ERnie
2016 BSM/f80/ZCP |
01-23-2011, 05:22 PM | #21 |
177
Rep 6,631
So basically we can conclude that downpipes aren't worth the money on an N55. I am really disappointed in the power potential on this platform in comparison to what the N54 guys accomplish.
E90 LCI N54 6AT
01-23-2011, 05:24 PM | #22 |
114
Rep 2,428
Wow, yeah lean is mean but not at the cost of burning thing up, haha. Hopefully the tuned AFR's looked better? I mean 15:1 under full boost (even if stock 7-8psi) just doesn't seem right.
The tune dyno still shows that sag in the 3-4k range... Now is this engine the Valvetronic engine? (No throttle body) Perhaps that will need a bit of tuning to allow it to deviate from stock logic, which is generally based on emissions and fuel economy. |
