325i -> 330I FACTORY conversion
01-16-2011, 03:19 PM | #1 | |
43
Rep 335
The question: why 330 software needs to be flashed? The assumption at the board is software is identical, but behaves differently based on VIN # |
01-16-2011, 04:56 PM | #2 |
Freight Dawg
104
Rep 2,103
I don't remember reading any assumption the the software was identical. In fact, just the opposite is true. The software on the 325 is different from the 330. The reason BMW techs can't just flash it to your car is because of the VIN. Some people can change the option list but not your average tech. If you try to force it on, the software vin will not match the cars VIN and that will cause issues. I think XDR's post fixes the issues.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
01-17-2011, 01:40 AM | #3 | |
43
Rep 335
Personally, I'd prefer to convert my 328i to 330i factory settings. I don't like the idea of after-market tuning... And I do not believe after-market shops are able to utilize 3-stage manifold advantage as they simply do not have enough knowledge and equipment. |
01-17-2011, 03:55 PM | #4 |
Rep 4
325 328 dme software do not recognize Three-Stage Intake Manifold
flash 330 software necessarily ...may 325 tuning software recognize Three-Stage Intake Manifold ? e90pilot try remove connector from DISA actuator motor and read error from DME or test DISA actuator motor DIS or ISTA/D if error not will appear 325 tuning software do not recognize Three-Stage Intake Manifold ..... |
01-17-2011, 06:22 PM | #5 |
Freight Dawg
104
Rep 2,103
Let me try that. I do know the factory software will operate the DISA motors at the correct rpm. Maybe it doesn't look for faults. I'll check with Active Autowerke on this. I'll unplug a DISA motor and see if I get an error.
--Marcelo
01-17-2011, 06:33 PM | #6 |
just another bmw douche bag
195
Rep 3,640
I can also confirm that the DISA motors function with the 325i DME. I tested them before installing in my car, and both opened and closed at the appropriate RPMs. The valves may operate on a passive rpm signal, without being monitored by the DME.
01-17-2011, 09:46 PM | #7 | |
making his own parts.
41
Rep 142
Is the process all done in the DME? because I'd like to try a 330i DME instead of reflashing my original 325i dme. thanks
For Sale: Jet Black pre-LCI front bumper/hood/trunk lid, oe tail lights, 2 oe 16 inch rims w/ good tires. PM w/ offers. |
01-18-2011, 07:28 PM | #8 |
35
Rep 323
are people really stillll discussing this? This is like 5 years old of information. it is NOT possible folks. You can get extra power but nobody yet has reached the power of a 330i from a 325/328. Its just not happening
01-19-2011, 11:05 AM | #9 | |
41
Rep 142
(and part of the reason being, experienced people aren't willing to share new information... and I don't blame them... why should we? everyone presumably already knows everything there is to know about this motor right?)
For Sale: Jet Black pre-LCI front bumper/hood/trunk lid, oe tail lights, 2 oe 16 inch rims w/ good tires. PM w/ offers. Last edited by allmotorh22; 01-19-2011 at 02:15 PM.. |
01-19-2011, 01:21 PM | #10 |
Old Geezer
360
Rep 1,193
Drives: 08 E92 N53B30
325i software will recognize DISA and operates the flaps (tested on dyno).
I had 330i software loaded into 325i ECU but the car lost power and I had to reload the original software. With tuning you can get more power from 325i (3l engine) than standard 330i. I’m not the only one who done that.
01-19-2011, 01:40 PM | #11 |
41
Rep 142
yeah,
but I don't think anyone has actually taken a physical 330i DME (or even another 325i DME for that matter) plugged it into their 325i and got it to work. if anyone know how to do this, please share. this would be a great help.
For Sale: Jet Black pre-LCI front bumper/hood/trunk lid, oe tail lights, 2 oe 16 inch rims w/ good tires. PM w/ offers. Last edited by allmotorh22; 01-19-2011 at 01:59 PM.. |
01-19-2011, 01:52 PM | #12 |
Old Geezer
360
Rep 1,193
As far as I know nobody successfully modified 330i software for 325i. Tuners are modifying 325i software.
01-19-2011, 02:32 PM | #13 |
Rep 4
allmotorh22
because I'd like to try a 330i DME instead of reflashing my original 325i dme. thanks This not help . After changing DME need change ISN in CAS or ISN from your CAS write in 330 DME .After this the car lost power, same if 330i software load into 325i ECU . But if in CAS change coding CLASS_PWR keine to klasse_2 all will be ok . If buy key ,CAS and DME from 330i only need coding CAS according your VO (option list ) |
01-19-2011, 03:33 PM | #14 | |
41
Rep 142
What do you use to code CAS and DME? (BMW tool?) ISN = VIN / Mileage?
01-19-2011, 04:47 PM | #15 |
Rep 28
Was just doing a bit of surfing on RealOEM and it looks like the US Spec 325i/330i uses an MSV70 DME unit. It looks like the 128i/328i N52 or later European 330i use an MSV80 DME unit, and the N51 128i/328i use an MSV80.1.
Does this mean that those of us that have 328is (or a 128i in my case) would need a DME (or at least the software) from a European 330i (or 130i) to get this to work? |
01-19-2011, 04:56 PM | #16 | |
81
Rep 741
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] |
01-19-2011, 05:07 PM | #17 | |
41
Rep 142
Anyway................ @XDR Will this work for coding the CAS and DME? http://cgi.ebay.com/ebaymotors/BMW-O...motiveQ5fTools
01-19-2011, 06:50 PM | #18 |
35
Rep 323
dude do some searching this topic has been hammered to death and nobody with a 325/8 has dynoed a car producing as much as a 330 so budvlad stop spreading lies. No tune of a 325 with an 3 stage intake is going to make 330 power. The tuners have not got it down like the bmw engineers.
01-20-2011, 02:23 AM | #19 | |
Old Geezer
360
Rep 1,193
BTW: Wintertuning (Forstern, Germany) is claiming 201 kW (273 hp) for 125i/325i . He does the tuning by downloading the original software to his notebook and sending it to somebody who works for BMW AG (according to Winter on software development). However, unlike DS Motorsport he doesn’t have dyno.
01-20-2011, 05:36 AM | #20 |
Rep 69
Dude, who the hell are you to come on here time after time and call people liars? What are your qualifications? You add nothing to this board. All you do is come on time and time again and complain and shoot down people's ideas with nothing to back it up.
01-22-2011, 12:02 AM | #21 |
81
Rep 741
I have an '06 E90 and i approve this thread. we need a conclusive method to completing this conversion already ffs.
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] Last edited by BOSSBMW; 01-22-2011 at 09:35 PM.. |
01-22-2011, 09:29 PM | #22 |
73
Rep 1,375
your turn to do it!
Current 2008 M6 e63 v10 6mt Current 2012 e70 x5 35i -jb4 2008 335xi e92- Sold 2007 335i e90 - Sold 2002 Taig / Red / / / M3 - SOLD |
