DIY - E90 Oil Change (with Pics! - 56K Beware)
09-22-2005, 01:28 AM | #1 |
37
Rep 69
E90 Oil Change (DIY) I would like to share my experience of changing the oil in my 2006 BMW 325i (e90) with sport package. My car has only 2300 miles on it, but I thought I should do a post break-in period oil change. (More on this later.) It took a bit longer than expected (~1 hr) because I didn’t know where everything was, especially the drain bolt. The job itself was simple - something I would do in about 15 minutes next time. Equipment and Tools: Rhino Ramp 17mm Socket Wrench Strap Wrench Supplies: BMW Oil Filter ~$15 BMW Synthetic 5W30 Oil, 7 Quarts (6.5 L), ~$5/Quart Lifting the car: One of the most difficult parts of my oil change was raising the car. I have a hydraulic jack, but I had two problems. 1) The jack couldn’t slide underneath the lift point, even though I would hardly classify my jack as being high. The clearance under the front of the car was minimal with the sport package. I could slip the jack underneath the rear of the car, but I needed to raise the front. 2) Even if I were to raise the front of the car with my hydraulic jack, there weren’t any lift points where I could place my jack stands. Frustrated, I went to buy some Rhino ramps. Unfortunately, the Rhino ramps had their own problems. While fellow forum member HRC didn’t have a problem (HRC, do you have a non-sport package e90?), I had a problem with the ramps slipping on my concrete garage floor. The culprit turned out to be the low hanging rubber flaps just ahead of the front wheels as shown below: While the flaps are flexible, they scrape the ramps enough to push them forward. This was quite frustrating. I finally solved the problem by putting the ramps on top of rubber floor mats I had lying around. They provided enough friction to prevent the ramps from slipping. Removing the oil cap and filter: Removing the oil cap was simple. Just turn the square cap clockwise and you’re done. Removing the oil filter was simple, too. I couldn’t turn the oil filter cap by hand, so I used a strap wrench. The exposed filter element is shown below: Removing the drain bolt: This took much longer than anticipated, simply because I didn’t know where it was located. The first thing you notice looking underneath the car is that plastic shields cover nearly the entire underside. Conspicuously, there is a large exposed bolt right where you think the middle of the engine is. I don’t know what this bolt is for, but IT IS NOT THE DRAIN BOLT. Fortunately, I didn’t loosen it because of heads up by fellow forum member HRC. BMW, in its infinite wisdom, made this bolt 17mm in size, same as the drain bolt. So if you’re looking for something that fits a 17mm socket in search of a drain bolt, this is it. However, don’t remove it. Even after some search, I still couldn’t locate the drain plug. I was in the process of removing the bolts securing the plastic shield underneath the engine (while cursing BMW and their poor design), when I came across this trap door just behind the bolt. When I opened it - Eureka! - I found the drain bolt! From here on, it was easy. Loosen the bolt and drain the oil into a pan. About 7 quarts (6.5 L) will drain out. Replacing the Filter: Let the oil drain for a few minutes. Meanwhile, you can replace the oil filter. The old oil filter next to the new filter is shown below. Inside the filter box, there should be two rubber O-rings (small and large) and one copper crush washer. Remove the two O-rings and the filter from the filter housing, and insert the new ones. It’s a little tricky removing the O-rings, but don’t use a screwdriver since it can damage the housing. The new assembled filter housing should look like this: Putting it back together: Screw the oil filter cap back on. Be sure the rubber O-rings, especially the large one, are in their correct grooves. I accidentally placed the large one inside a wrong groove once, and oil started gushing out of the housing. Go underneath the car again, and screw the drain bolt back in. Make sure you pry off the old crush washer, and use the new copper crush washer. Secure the trap door. Finally, put ~6.9 quarts of BMW Synthetic 5W30 oil in. Once finished, secure the oil cap. Start the engine and check for any leaks. Drive off the ramp and drive for a few miles because the on-board computer needs a few minutes to get an accurate reading of the oil level. Check the oil level through the on-board computer, and top off as needed. You’re done! Simple! Postscript: Again, it should only take ~15 minutes to change the oil once you get the car on the ramps. It is a very simple procedure. Now, the question of whether it was necessary to do a post break-in oil change: I’m going to be somewhat diplomatic. Quite frankly, the used oil appeared to be pretty clean (I did not see any metal shavings nor notice significant change in its viscosity). In my professional judgment (Ph. D. in engineering), I would say that my oil change at 2300 miles was overkill. The evidence isn’t convincing enough to support the need for one. However, in my personal judgment (a person who is obsessive about his new car and wants it to last forever - and quite frankly, who isn’t on this board?), it was worth the reassurance that there won’t be a nagging question in the back of my mind always wondering whether I should’ve changed the oil after the initial break-in period. Would I again change the oil after my break-in period, given what I now know about the state of the oil after 2300 miles? Absolutely! You can’t always be rational about a car – otherwise we would all be driving Toyotas. Edit: For some reason, my account where I hosted the images disappeared. I the meantime, I attached as many relevant pictures as possible. If anyone can help me out finding an appropriate host for the original images, please let me know. Thank you. Last edited by e90wraith; 03-11-2007 at 03:31 PM.. |
09-22-2005, 05:39 AM | #3 |
Photographer
40
Rep 313
I have never tried to change oil myself so I may sound dumb but help me with this question. How much torque do you need on tightening the drain bolt? What about oil filter? Should the oil filter tightened by hand? What do you do with the old engine oil?
09-22-2005, 08:03 AM | #5 |
e90 newbie
35
Rep 448
Excellent writeup with pictures - Thank you. I plan to do a break in and mid interval oil changes myself and your pics were invaluable.
As for torque, I'm not a pro, but having done oil changes on my previous cars: 1. Tighten the drainbolt with arm strength. Don't go crazy. The copper washer is there to be slightly crushed and form a tight seal. If you overtighten, you could strip the threads on the bolt or worse - engine block. Unless you're a bodybuilder or use a ridiculously leveraged wrench, this is unlikly to happen. 2. Oil filters can be hand tightened 3. Old oil can be recycled at your local autobody/parts store. They ususally have a oil depot/tank that you pour the old stuff into. I funnel my old oil into leftover Tide/laundry detergent cointainers (clean ) and drain it at the recycle centers. Do not dump the oil in the trash or down the drain - bad for the environment and it's illegal. Hope this helps Last edited by MCS; 09-22-2005 at 08:14 AM.. |
09-22-2005, 09:08 AM | #6 |
331
Rep 817
e90wraith, thank you very much. This write-up is incredibly clear, concise, and thorough. I'll definitely be doing my own changes when my car arrives. I do have a few questions. How does this affect the maintenance indicator? Does it automatically reset itself, or can that be done as a DIY, or does the dealer have to do that. If so, will they charge you to reset it and then void your free maintenance?????? Thanks again for taking the time to put together this post!
09-22-2005, 10:38 AM | #7 |
7
Rep 244
Great write up...BTW, my mechanic friend told me that the BMW oil is made by the same people that makes Mobil 1. So he told me that it would be perfectly okay to use Mobil 1 5W-30 synthetic oil. As for the filter, I guess it should be OEM.
Thanks a lot....I think I will do the same and change oil at about 2500-3000 miles. It looks easy enough to DIY. An then do a 5K interval after that. |
09-22-2005, 10:55 AM | #8 |
27
Rep 303
GOOD ONE!
I am done with the break in miles, and was just thinking of doing the change myself!!! GOOD PICTURES and THANKS FOR SHARING! |
09-22-2005, 12:41 PM | #9 | |
37
Rep 69
09-22-2005, 12:56 PM | #10 | |
37
Rep 69
Oddly, the BMW manual says that approved oils are BMW synthetic and Mobil 1. It doesn't mention Castrol - so go figure... Some have speculated that Castrol oil in Europe is different from those sold in the US. Last edited by e90wraith; 09-23-2005 at 02:44 AM.. |
09-22-2005, 03:04 PM | #12 |
e90 newbie
35
Rep 448
One interesting thing to note is that the pic of the dirty filter had anumber of silvery/white looking particles. Not trying to stir up any debate on the break in vs no break in oil change.
e90wraith, were these particles (1) real and (2)were they metallic or other junk? Maybe I'm just being anal which I suspect is the case as well... |
09-22-2005, 05:16 PM | #14 | |
37
Rep 69
I think the white specks you are seeing in the dirty filter are the white spots in the filter paper. If you look at the close up pictures of the brand new filter, you see them as well. Last edited by e90wraith; 09-22-2005 at 05:32 PM.. |
09-22-2005, 08:47 PM | #15 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Great pictures and write up! I do have the zsp option on my car. I'm thinking the reason why my car didn't push the ramps forward is because my driveway is at a slight incline and I was facing up.
I'm going with 7500k intervals for the oil change. I have complete confidence in the oil for 7500 miles. Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
09-22-2005, 10:36 PM | #16 |
Custom User Title
17
Rep 215
Bravo! Thank you for taking the time to take the pictures and write the description. The location of the drain plug behind the trap door is great info.
Couple questions for ya: 1. Did you measure the new oil, or just try to get close, then check the electronic gauge and adjust, or what? Guess I'm and old fogey and miss having a dip stick, which has been a wholly reliable device on every car I've owned. 2. What about pre-filling into the filter compartment - is it possible? I'd always dumped a-third-of-a-quart into a canister style filter before fitment .
tima
get off the phone and drive |
09-23-2005, 12:59 AM | #17 | |
37
Rep 69
2. I guess you can prefill the filter housing. I'm not sure what benefit it would have. Unlike some canister filters, it does not have a flow-back check valve. It is completely open on one side. So you will spill some or all of the oil putting it back on - especially since it's vertical. |
09-25-2005, 02:12 AM | #18 |
Rep 24
Based on the above picture of the BMW oil the specs are SAE 5W30, API Service: SL/CF; ACEA A3/B3.
So which of those Castrol oils matches the above? SYNTEC 0W-30 API SL/CF. ACEA: A3, B3, B4. VW 502 00, 505 00, 503 01. BMW Longlife-01. MB 229.1, 229.3. Porsche approved. The grade doesn’t match, but API and ACEA specs do. SYNTEC 5W-30 API SM, SL, SJ/CF. ACEA: A1, A5, B1, B5. GM 6094M, GM 4718M. Ford WSS-M2C929-A. ILSAC GF-4, GF-3, GF-2. The grade does match but ACEA spec doesn’t. |
09-25-2005, 02:15 AM | #19 |
Powered By 36DD
337
Rep 7,369
Thanks for the information, I'll be changing my oil in a couple of weeks......I'm at 4,200 miles.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
09-25-2005, 05:04 AM | #20 | |
1311
Rep 10,185
The BMW one is Castrol TXT. It does not seem to be available anywhere in the USA or Canada other than at the BMW dealers |
09-25-2005, 05:04 AM | #21 |
1311
Rep 10,185
Guys please note the approved Mobil 1 oil is the 0W-40 one
The bottle must say its BMW LL01 approved http://www.mobiloil.com/USA-English/...l_1_0W-40.aspx |
09-28-2005, 01:04 PM | #22 |
44
Rep 722
Excellent post! I will be using this over the weekend!
One question: Do the Rhino Ramps give you adequate clearance under the vehicle, and did you find they were wide enough for your tires? I have a 330i with sport (and 18 inch wheels) and I am afraid the tires will hang off the sides of the ramps). |
