BMW X3 Forum
BMW X3 Forum
      01-02-2011, 09:44 AM   #1
///MPower_2014
42
Drives: '11 E90 M3
What is the " auto h" button below the parking brake button?
See subject for question.
      01-02-2011, 09:49 AM   #2
fedinand
fedinand's Avatar
Drives: '11 X3, '11 GTI
auto hill hold function i believe...
      01-02-2011, 09:49 AM   #3
jijioben
17
Drives: 2011 F25 X3 35i
It is the auto hold feature that keeps the parking brake on as you release the brakes until you push on the accelerator (up to a maximum of about 5 seconds). This way, you can start on slopes without backing up when you release the brakes. I tried it on the X6 and I found I could not get used to it: I like releasing the brakes myself. But I have not tried in on the X3 yet... Here's hoping it is as much improved as everything else.
      01-02-2011, 09:06 PM   #4
CarolinaBlue
Drives: 335d
To each their own. I've used it a couple of times and liked it each time.
      01-02-2011, 10:09 PM   #5
Tauvil
Drives: 2011 X3 35i - Black Sapphire
Didn't realize it's only good for about 5 seconds. Good to know before I tried it at a red light while reaching into the back for something!
      01-02-2011, 11:24 PM   #6
jijioben
17
I think I made a mistake: I read the X5/X6 manual again and there is no mention of the 5-second rule. I definitely waited for longer than 5 seconds while driving with no ill effects. I remember reading about the 5-second delay somewhere, but it must have been for another feature, and I confused it for Auto Hold.
Apologies!
      01-12-2011, 09:45 AM   #7
Nahoa
Drives: F25 35i Mineral Silver/Black
Used it during a test drive and it held seemingly indefinitely. The dealer described it as a "hill hold" function (though I thought BMW steptronics did that automatically, so confused a bit there) but also more as a function for stop and go traffic. Need only use accelerator for short moves and the Auto H function stops and holds you between moves. Don't know if I can get used to that, but it worked on the lot . . .
      02-06-2011, 09:03 PM   #8
acer2974
Drives: X35i Min Silver/Black Int
Tried it. No time limit. It's great. Don't have to put your foot on the brake at stop lights. Just touch the throttle and it instantly releases.
      02-06-2011, 09:12 PM   #9
Nahoa
+1 re acer's comments; wasn't sure at first, but after 3 days I think I like the feature. Was a bit apprehensive at first sitting a stop lights and such, but the system held consistently and I realized that if it let go (no reason to think it would) it would be a simple thing to get my foot to the brake. Once I became confident in the system, it produced even smoother take-away from stop (for passenger comfort) than switching foot from break and onto gas and pressing down.
      02-07-2011, 10:43 AM   #10
kmarei
kmarei's Avatar
Egypt
686
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
by default is it on or off?
      05-11-2019, 10:32 AM   #11
DevsX5
Drives: 2017 X5 M sport
Does anyone know if autostart / stop turns off when using auto hold? My 2017 x5 has both of these features and I don't belive the auto start stop works...
      05-11-2019, 10:50 AM   #12
Wgosma
Drives: 2012 F25 X3 28i (N52)
Off
      05-11-2019, 05:47 PM   #13
MetaX
105
Drives: 2022 X3MC
They should rename it to "drive-thru" mode...
      05-12-2019, 11:10 AM   #14
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
See manual for solution
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      05-12-2019, 05:30 PM   #15
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
+1
Appreciate 2
      05-13-2019, 03:28 AM   #16
Msportdriver1
Drives: X3 35d M sport
People read your manual but just in case this is to difficult: the "auto h"button is to select the automatic handbrake function on. Instead of you using the handbrake button anytime you stop it instantly applies the handbrake and release's when you depress the accelerator. there is no time limit, it is not a specific hill start option it is just an auto handbrake. The only down / upside to it dependent on your point of view is it must be selected on every time you switch the car on.
scostu1623.00
      05-13-2019, 10:07 AM   #17
pokerface
pokerface's Avatar
432
Drives: F25 X3 N20 / F80 ZCP
car will not restart if Auto Hold applied the brakes and you release the brake pedal. once you apply throttle the engine will restart.
Bonus trick: you can also just pull up on the E Brake while the car is stationary and in Drive, and it will Auto Hold for you one time (you don't need to press the Auto H button)
      01-26-2023, 12:47 AM   #18
Paras Waiba
Drives: BMW X6
AUTO/H on my BMW X6 is an electric parking brake! Best used when you stop at Red lights just press the AUTO/H button (you will see a green message in your dashboard). NO need to put gear in N or press your brake! Once you have green light press the AUTO/H button again and drive! It is as simple as that!
      01-26-2023, 11:29 PM   #19
brianhinton77
90
Drives: 2011 X3 28i, 2016 X5 M-Sport
First resurrection of this thread ….8 years….second resurrection……3.75 years…the Auto H…
      01-29-2023, 05:50 PM   #20
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
If you don’t want to keep the brake pedal pressed when you’re driving from red light to red light or in a drive-thru lane or in stop-n-go traffic jam…there’s no need to keep pressing AUTO-H on and off. Once you have activated it…it will hold the brakes every time you stop…then just press the accelerator and it releases the brake as you move forward. Physically turning it off and on is redundant because it will hold the brakes every time you come to a stop…then release when you take off…all by itself without turning it off/on…hence the name AUTO-H.
As mentioned early on in this thread..the way this feature works is in the owners manual…and since iDrive has an embedded owners manual it is VERY easy to find using one of the search features iDrve. A KEYWORD SEARCH enter AUTO…should take you right to it.
There might even be an embedded video (animated explanations) in iDrive.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      01-29-2023, 06:35 PM   #21
bmwPower99
19
Drives: bmw f25 X3 35d
Another benefit of Auto H enabled is when you shutdown your car, the parking brake is applied automatically. Continuous use of the parking brake lever is known to crack the plastic.
      01-01-2024, 10:11 AM   #22
BMWZ4
BMWZ4's Avatar
1910
Few read their owner's manual...digital or print...wow...just drive, figure shite out as you go...yep, makes total sense 😂
xbimmers
