v5 for n55 ready for testing
12-28-2010, 12:51 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
We have n55 v5 ready to roll. But before releasing it, I'd like to get a few more testers run it for the next week. What's new: -persistent autotuning (no more resetting after mapswitch) -more command center functionality (same as n54 v5) -improved boost control algorithms (to address the tendency of the little turbo to boost creep in the higher gears). -NA mode/Map3 (actually runs 2-4psi since the turbo is so small it builds boost even with the wastegate fully open) -New in-dash display options (same as n54 v5). If you'd like to try it, email me at shiv@vishnutuning.com with "N55 v5 tester" in the subject line. Cheers, shiv |
12-28-2010, 04:06 PM | #4 |
798
Rep 4,784
Dunno, but it meant I lost that race lol...
ERnie
2016 BSM/f80/ZCP |
12-28-2010, 04:06 PM | #5 | |
24
Rep 269
Is there a way to force a reset of the autotune values? I say this for times when you want it to start over (think large swings in weather, gas quality etc..)
-Jose Quote:
12-28-2010, 04:08 PM | #6 | |
Rep 37
12-28-2010, 04:24 PM | #8 |
734
Rep 4,635
when will it be released i was planning on ordering it today
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
12-28-2010, 10:17 PM | #9 |
13
Rep 169
Drives: 2011 335ix M-Sport
I sent my email 6 hours ago... no software yet
12-29-2010, 06:20 AM | #11 |
Rep 37
12-29-2010, 06:32 AM | #13 |
34
Rep 522
12-29-2010, 06:49 AM | #14 |
Rep 37
Being that TC is a major feature of v5, I can't see how the N55 version would be released without it. But that's a question for Shiv, I guess. Regarding the DCT functionality, I don't know. You only asked about the N55 in general in your previous post.
12-29-2010, 08:53 AM | #15 |
293
Rep 1,514
Drives: Ever changing fleet
Basically, as you run up through the gears, the engine is placed under greater load, which adds extra energy to the exhaust stream and makes it easier for the turbo to produce more boost at a given WG duty cycle. If no change in the WG duty cycle occurred, boost slowly "creeps" higher as you move up through the gears. This extra energy has to be shunted around the turbine wheel, which is when the wastegate comes into play . Essentially there has to be an algorithm that notes the load of the engine (there are many ways of measuring or even deducing this) and then tweaks the WG duty cycle accordingly to keep the boost pressure from slowly rising.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
12-29-2010, 02:21 PM | #16 |
13
Rep 169
Anyone heard back from Shiv about this yet? I'm getting anxious!!
12-29-2010, 02:52 PM | #17 |
798
Rep 4,784
You might be a little late to the party...
ERnie
2016 BSM/f80/ZCP |
12-29-2010, 02:55 PM | #18 |
161
Rep 7,377
Come on guys its holiday season! Lets let Shiv recharge the batteries and have some quality times with his family! Whats the stress? The map will be sent when ready.
12-29-2010, 09:33 PM | #20 |
342
Rep 1,352
Drives: 2018 M3 CS
What about DCT specific maps for v5?
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
12-30-2010, 06:32 AM | #21 |
Rep 37
