Trunk Pass Through Plastic Crap
12-23-2010, 08:52 PM | #1 |
73
Rep 1,770
So tonight I was trying to fit my skis into the car for a ski trip tomorrow. (working on getting cross bars so my Thule's can go up there) This is the second time this has happened to me. I tried to take out the plastic piece to allow objects to pass through. I lifted up the handle to try to take it out and it got stuck. The handle is now stuck open. Does anyone know how to fix this or had this problem in the past? Last time I had this issue I went to the dealer and they rectified it for me.
Basically the plastic handle is stuck open so I can't close the hatch.... Thanks guys and Happy Holidays! |
12-23-2010, 09:00 PM | #2 |
253
Rep 7,089
Drives: '06 AW 330xi
You're not suppose to take out the whole box. There's a bag inside that you slid your skis into. There should be a small coin sized black button at the top right. Push that and it will open the door and a bag will magically come out.
However, it shouldn't be getting stuck like you mentioned. Have you tried pushing the whole panel back in? |
12-23-2010, 09:02 PM | #3 |
210
Rep 2,110
Where you going skiing? Hoping to get out next week. I have never had that issue with the ski bag and plastic holder
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build Retired: 2008, 2011, 2013 328xi |
12-23-2010, 09:31 PM | #4 | ||
73
Rep 1,770
Hunter, upstate NY. Stratton on Sunday, Hunter again next Thurs. Maybe Belleayre. |
01-03-2011, 07:16 PM | #5 |
73
Rep 1,770
Ok so I took some pics so maybe you can help me out, apparently the newer cars w/ cold weather packages do not come w/ the ski bag. Nor is it an option I've seen. I would like this so if anyone has one and wants to trade? I'll pay shipping, of course after i fix mine.
The plastic handle is supposed to be lifted up which retracts the latch and the plastic pass thru is removed. The handle retracts flush and the latch extends. Mine is stuck where the latch is stuck open as the removal position. I've taken out the springs and the latch piece so the handle is flush. Anyone have a clue? |
06-11-2011, 09:37 PM | #7 |
67
Rep 479
I have the fold down rear seats and there is no ski bag - only the empty cassette. The ski bag looks like an additional $150 option. I got my cassette stuck when I was inspecting it at the dealer when I picked up my car. I eventually got it put back in, but it took a couple minutes of fussing.
To answer your original question, I don't know how to get yours back together, but if it was mine, I would take it back to the dealer and ask them nicely to do it for me. Tom |
06-17-2011, 06:58 PM | #8 | ||
73
Rep 1,770
06-17-2011, 10:45 PM | #9 |
Rep 26
Thanks ! Good idea on trying to trade for one w/ a bag.
From what I can tell this one was not really mean to be removed. I've found though that it fits well (and pretty securely) w/out the springs and black tab and is actually much easier to remove. That's how I have it in there and I just have the spring and tabs stored in my toolbox. I guess there is a slight danger of it flying out if the back armrest is down and I make a super sudden stop .... but the chances of that are slim. Thanks again for the help! |
06-18-2011, 12:48 PM | #10 | |
73
Rep 1,770
03-05-2014, 05:09 PM | #11 |
17
Rep 35
Hi All, I know this is an old post, but I just managed to fix mine so I thought I'd post a reply as this was the first hit in the Google search I did. Basically, there is a thin plastic trim piece just above the button that is visible in the above pics. Pull this trim piece off and you will see the hinge for the handle that removes the whole box. The hinge moves on 2 pins that can be removed towards the outside of the box. To do so, I drilled 2 small holes in the closed plastic ends of the hinge opposite of the open side of the pins and pushed the pins out with the drill bit. Then you can re-assemble the whole works and snap the trim piece back in place. I hope this helps.
03-05-2014, 05:28 PM | #12 |
Fuck it dude, let's go bowling.
888
Rep 2,480
Anyone who wants a ski bag - PM me. Local pickup, or just pay shipping. I hated that thing - my kids kept popping the button and I was constantly having to refold and put it back together. I finally took the bag out.
Note - I only have the bag and retaining frame, not the entire unit. The bag should pop into any unit that does not have one. Dunno?
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
03-05-2014, 06:08 PM | #13 | |
281
Rep 4,121
08-07-2016, 08:34 PM | #14 | |
90
Rep 389
Drives: 2009 E90 M3 AlpineWeiss 3
02-19-2017, 06:35 PM | #15 |
Rep 1
Avoid cutting off plastic caps, use knife in between hinges to slide pin out
I used a knife to slide the hinge pins out without cutting off the hinge end cap. I only needed to take one hinge pin out to slide the piece back into the slot. This is a poor design BMW if you are listening--as are your pop out cup holders that always seemed a little flimsy and get banged by knees all the time.
08-14-2018, 04:03 PM | #16 |
Rep 13
Help - Battery Disconnected - Need To Remove Cassette To Get Into Trunk
How do I get that damn cassette out- cant access trunk , battery is disconnected !!
Any ideas? (Jump/Boost doesn't work to work the trunk button ) |
08-15-2018, 09:07 AM | #17 | |
118
Rep 342
https://youtu.be/pyjRqzv1cpA
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
03-07-2022, 03:18 AM | #18 | |
11
Rep 153
