HELP! Car possibly not recognizing key fob
12-23-2010, 05:36 PM | #1 |
Cuba
81
Rep 1,676
Yesterday I drove my car for about an hour, when I was ready to leave I tried to unlock my car using the key fob and nothing happened. Next I tried to open the handle of the car (I have CA) and nothing happened. I used the manual key and lock to open the door and get inside to try to figure out what was going on.
At this point I try to put the key in the slot to see if anything happens, and nothing. I try turn the dome lights on and nothing. About 5-10 minutes later the car turns on and starts working again. After I drive home I go back to my car to get something and the same thing happens again. This has occurred a total of 5 times over the course of 4 months. Once when I was completely stock about 4 months ago, once 2 months ago, and 3 times over the past two days! Im thinking maybe the key is not being recognized by the car when im close. I would like to add that after the car begins working again, I have to re enter the time and I get a message that says AWD and DSC has malfunctioned, but this message goes away when I begin moving. I would appreciate any help on this subject, any tips or possible solutions to this would be greatly appreciated. Also the key fob battery was changed after the first time this happened Thank you e9x'rs
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
12-23-2010, 07:02 PM | #2 |
45
Rep 1,754
Change the battery in the CA fob. You are right on track in terms of time for the battery to have died. Non-CA fobs recharge -- CA fobs have a disposable battery.
12-23-2010, 07:34 PM | #3 |
I ask the questions you're afraid to ask.
44
Rep 2,489
Did the first incident happen before the battery change?
I give you the answers you don't want to hear but you know deep down that I am right.
12-23-2010, 07:42 PM | #4 |
Cuba
81
Rep 1,676
12-24-2010, 03:36 AM | #5 | |
Where'd my VTEC go?
481
Rep 6,067
And dome lights should work at all times. Even if you smash the window and turn them on. So....car issue, not fob issue.
12-24-2010, 08:24 AM | #6 |
44
Rep 2,489
Did you make any mods to the car (electrical or otherwise) around the time when you first started having issues? Tint, suspension etc?
12-24-2010, 08:50 AM | #7 |
Cuba
81
Rep 1,676
Right around the first time it happened the only thing that I had installed was LLumar tint. Since then the only mods that would most likely defect it is an AE and fog upgrade, but those chances are probably slim.
12-24-2010, 08:52 AM | #8 | |
Cuba
81
Rep 1,676
12-24-2010, 09:20 AM | #9 |
253
Rep 7,089
Drives: '06 AW 330xi
Your CAR battery is causing the AWD and and DSC malfunctions. When you disconnect the ground for your battery, your car will go through a system check of some sort when you re-install the ground.
This always happens after removing my ground....and obviously the AWD error is xdrive related. I'm not sure about if the non-xdrive models have the DSC error after a battery disconnect. Check your cables. Make sure nothing is lose. Also get the voltage checked out....your battery may not be holding a proper charge. A good battery will hold somewhere around 12.6 when off. Anything under 12.1, you need a new battery. But you can also try charging the battery with a tender.....before replacing. In the event your battery doesn't hold a charge, certain systems will be limited. CA being one of them. I've noticed a bunch of '06 and '07 models needing a battery replacement about now.....including me. I'm waiting for a braille lightweight battery to come in today. I've been getting slow cranks and the only reason my car turns over is because of the cap for my audio system. My battery is holding between 11.5 and 12.1, off. And it will quickly drain from 12.1 to 11.5 when the car is sitting. Last edited by fdriller9; 12-24-2010 at 09:25 AM.. |
12-24-2010, 09:41 AM | #10 | |
Cuba
81
Rep 1,676
12-24-2010, 09:44 AM | #11 | |
1705
Rep 14,829
Does one really believe that BMW would be so stupid that if your 2032 battery died, the entire vehicle shuts down? Uh oh, better not answer that. |
12-24-2010, 09:48 AM | #12 | |
1705
Rep 14,829
12-24-2010, 09:56 AM | #13 |
253
Rep 7,089
^ Try charging it with a trickle charger.
12-25-2010, 11:33 PM | #14 |
Cuba
81
Rep 1,676
bump still need some help on this. Car is sitting at a shop, hopefully will be getting a call tomorrow letting me know the status
12-31-2010, 10:44 AM | #15 |
Cuba
81
Rep 1,676
Bump. Still need help on this, car has been at mechanic for about a week now. Any comments appreciated
01-09-2011, 05:05 PM | #16 |
Cuba
81
Rep 1,676
*UPDATE* - One of the cells in the battery was dead, so the battery was replaced, drove the car fine for a couple of minutes..
About an hour later I go to drive it again and nothing works, key fob doesnt unlock doors, I used the manual key to open the door and the dome lights do not work.. Please just throw out any suggestions on what you think it is.. Thank you
01-09-2011, 06:14 PM | #17 | |
253
Rep 7,089
01-09-2011, 07:32 PM | #18 |
Cuba
81
Rep 1,676
Okay thank you
01-09-2011, 07:59 PM | #19 | |
Cuba
81
Rep 1,676
is it possible that if i use a capacitor the car will not have any problems?
01-09-2011, 08:24 PM | #20 | |
253
Rep 7,089
01-19-2011, 04:56 PM | #21 |
Cuba
81
Rep 1,676
car was at dealership... the junction box had to be replaced. Hopefully this is the final solution to this problem
