Slight Delay When Transmission Engages
12-22-2010, 04:28 PM | #1 |
Rep 19
Hi guys,
My car (Automatic) has a split second delay when transmission engages if I press the acceletator pedal. This is when you are at STOP which means that you're foot is at the BRAKE pedal and about to drive the car. When I release the brake pedal and step on the Accelerator, there is a split second gap before the transmission gear engages. Thus, when you accidentally step on the accelerator faster, the car will jerk because the car is already in a high rev before it actually engages the transmission gear. Does anybody experience this on an E90? |
12-22-2010, 04:33 PM | #2 | |
11
Rep 293
12-23-2010, 02:53 PM | #6 |
12
Rep 433
My 328i does this and not only is very annoying, it can be rather dangerous. When I press the pedal (generally under 15 MPH) the car will lag and then slam into gear. My dealership has reprogrammed the transmission which resulted in a slight improvement.
f30 335i: Current
e92 335i: Sold 10/29/2015 e90 328i: Sold 12/7/2013 |
12-23-2010, 02:54 PM | #7 |
12
Rep 433
If you have an AT, then you have Sport Mode....
f30 335i: Current
12-23-2010, 11:06 PM | #9 |
149
Rep 6,604
Drives: e92 335i
very normal in an automatic but not in sport mode
12-23-2010, 11:56 PM | #10 |
124
Rep 2,554
This used to happen to me when i drove more cautiously, but now that i go hard all day, there's no delay
12-24-2010, 01:19 AM | #12 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
12-24-2010, 09:36 AM | #13 |
253
Rep 7,089
Drives: '06 AW 330xi
I think this is caused by the Neutral Idle Control, NIC.
This was also a problem for the "sticky brake" issue. EDIT: Fluid won't do anything. Your transmission should act/feel the same way after a fluid change. If not, there' something else wrong with your transmission. |
12-24-2010, 09:53 AM | #14 | |
46
Rep 541
Don't listen to TurkeyBaster. ZF Lifeguard6 is NOT "the same as" or "just repackaged" (TurkeyBaster's claim) Motorcraft Mercon SP. One is red, the other is honey-colored. they smell different. Maybe Mercon SP meets the same specs, but i wasn't going to take that chance. I sent the Mercon back (except for the one quart I opened) and bought Lifeguard6. As for shifting, there is definitely a different feel to the shift points and the "hardness" of shifts after the fluid change; not surprising given the state of the old fluid. I went ahead and reset my adaptations so as to let the ECU "learn" again, what with the mechanical part acting a bit differently now. |
12-24-2010, 09:57 AM | #15 | |
46
Rep 541
12-24-2010, 10:29 AM | #16 |
Rep 29
Although you have a 325, this link might help explain what is going on. It would appear an update to your transmission software is probably in order, or just live with it.
http://www.bimmerfest.com/forums/att...4&d=1237235515
Mike
12-24-2010, 10:33 AM | #17 |
253
Rep 7,089
^I've seen that TSB before. However, disabling the neutral idle control will decrease gas mileage.
That' why I choose this live with this. |
12-24-2010, 10:35 AM | #18 | |
253
Rep 7,089
But in general, you shouldn't feel a significant difference in swapping the tranny fluid. |
12-24-2010, 11:04 AM | #19 | |
103
Rep 2,783
