Winter tyres ordered - pressures?
12-22-2010, 09:58 AM | #1 |
310
Rep 1,314
Managed to order a staggered set of Falken HS-439 to fit on the OE rims. Does anyone have any suggestions as to the correct pressure? (Used search)
12-22-2010, 11:05 AM | #3 |
6659
Rep 15,858
There is opinion (which includes Tirerack) that it's best to run a bit higher than the summer tyre. About 3 - 5psi higher is suggested.
There's a tech page on Tirerack with some of the reasoning. HighlandPete |
12-22-2010, 01:42 PM | #4 |
Rep 40
Just got my set today. 225/45/17 all round on original staggered msport alloys.
My tyres, dunlops, are not runflat so do the pressures differ from the plate recommendations? |
12-23-2010, 06:01 AM | #5 | |
Rep 473
Logic would surely say to go higher on snow to make the sidewalls more rigid and softer on ice to maximise the footprint, surely? Non-ZP tyres generally need a couple PSI more in them than ZPs, Jamm, so add that to the formula anyway..! |
12-23-2010, 10:54 AM | #6 |
1545
Rep 8,970
The M+S pressures on my rating plate are higher than the same sizes of summer tyres.
Also if you're using a narrower rear then you'll need higher pressure to support the same weight. Again, find the same width on your rating plate and go with that to start with. |
