DTC/DSC cutting my power...
12-20-2010, 09:25 PM | #1 |
100
Rep 1,143
Drives: 2020 M2C DCT
I have posted twice here concerning a problem with my 2011 335is. Upon pedal to the metal hard acceleration, I lose power briefly until I back off a bit and press down on the accelerator gradually. I did some research and the cause, I think, is that the DSC (dynamic stability control) /DTC (dynamic traction control)couple is designed to cut power if it senses any forward wheel spin or lateral instability which is probably the case when you stomp the accelerator!!! Anyone agree with my conclusion? And that said, how the hell do you accelerate hard from a dead stop. From what I read,turning off the DSC is unwise and not a viable option.
"The sleep of reason brings forth monsters."
12-20-2010, 09:32 PM | #2 |
509
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
The DTC button works in two stages. Press it briefly and it will reduce the negative that you experienced - it will allow some wheel slip. Hold it down longer and it is all off and loads of fun - unless you are on wet/icy/snowy roads or driving really hard..
12-20-2010, 09:34 PM | #3 |
COBB'ed
65
Rep 2,228
^ yep.
13 Mini Cooper S 08 E92 335i (SOLD) |
12-20-2010, 09:40 PM | #4 |
67
Rep 1,543
Drives: M235i
You've pretty much got it figured out, if you want uninterrupted acceleration (with inevitable wheelspin) just hit the DTC button once. Hit it again to re-engage it. Personally I don't like turning DSC off, it just doesn't feel right, I wouldn't recommend turning that off unless you know what you're doing. I actually find it necessary sometimes in the snow to turn off DTC though to get the car moving, just don't forget to turn it back on once you get moving, made that mistake last winter and ended up on the side of the highway from the wheels spinning when I changed lanes.
12-21-2010, 10:46 AM | #6 | |
12
Rep 242
Drives: 2011 F10 528i
For winter driving, I do exactly the same ... hit the DTC button once to get going from a slushy start, and then hit it again to turn DSC back on.
2011 528i Space Gray - Black - Light Wood Trim
2006 325xi |SG - Terra - Walnut | Steptronic | Premium Package - Nav | Zenon Adaptive Headlights | Blacklines; iPod Adapter |
12-21-2010, 10:59 AM | #7 |
just another bmw douche bag
195
Rep 3,640
you need to modulate your right foot. if DSC is kicking in, you are giving it too much throttle. you need to learn how to balance it on the edge of adhesion.
12-21-2010, 11:14 AM | #8 | |
100
Rep 1,143
Down here we pronounce it baa ( the noise a sheep makes)-ton (2000 lbs) while some pronounce it like the word "batten" as in "batten down the hatches." I'm not french, so I don't know the proper french pronunciation but it is more like "buh-tun" with stress on the first syllable.
12-21-2010, 11:15 AM | #9 |
100
Rep 1,143
Good advice, thanks.
12-21-2010, 11:18 AM | #10 | |
100
Rep 1,143
12-21-2010, 11:34 AM | #11 |
14
Rep 345
I usually hit the button once when I want to drive semi-aggressively....and save full "off" for controlled situations. I have left it totally off accidentally and been surprised when pulling hard out of a turn with a swinging rear end which I then have to reel in ... the car behaves totally different when the dsc/dtc is off and you def need to get used to it both ways. I have shown my wife the difference and she basically will not touch the setting after seeing what can happen
'09 135i - Step - Sport - M.Blue - JB3 - Eibach Drop -Alufelgen SF-71 for 1 Series
'08 535i - Step - Sport - JB3 - BMS Air Filter - HKS BOV/Pipe - Aquamist water/meth injection - EuroLights Yellow ION Foglight Bulbs - |
12-21-2010, 11:39 AM | #12 | |
One cam is enough
130
Rep 6,801
12-21-2010, 11:47 AM | #13 |
14
Rep 345
Yup...I agree...it does pull power very aggressively. I guess what I'm saying is that you always need to be conscious of the setting you are in b/c it definitely does work and you might expect the car to do one thing and it does the other
12-21-2010, 11:52 AM | #14 |
One cam is enough
130
Rep 6,801
I agree. The spirit of my post wasn't to disagree at all.
12-22-2010, 11:16 AM | #15 |
67
Rep 1,543
Drives: M235i
12-22-2010, 11:31 AM | #16 | ||
Enrollment Officer
114
Rep 5,014
If you track your car, then take nannies off when you have taken advance driving lessons. I think this advice will save your car, save your surroundings, save your life and save everyone else that will cross your path. Quote:
what he said. |
