Consumer Reports 335i Reliability
12-17-2010, 02:10 PM | #1 |
289
Rep 864
335i placed 35th out of 35 Upscale Cars.
. . Specifically a -70 rating vs a +60 rating for Acura TL. . . My Thoughts: If relability relates to cost -- The BMW NEW Car Warranty over comes this hurdle. The HPFP issue is most likely at the root of the low score. To date my 07' 335i has seen one problem where she spent a week at the dealership for a bad speed sensor and wheel bearing ~ all covered. Beyond that, I have had no issues in 45k miles. I often read that ownership beyond 50k is crazy expensive. Well - my previous experience shows that this is more of a function directly related to the maintenance schedule the owner follows. I do follow the Mike Miller "old school Maint" plan and look forward to my next 50k with my very reliable 335i. Regardless the 335i is the absolute best car - each time I run through the gears I get a sense of confidence and general thrill -- this is a GREAT DAILY driver. THROW THE CONSUMER REPORTS IN THE GARBAGE - it is more of an appliance index -- the 335i is definately NOT! |
12-17-2010, 02:15 PM | #2 |
3573
Rep 10,352
CR isn't exactly the most reliable when you understand their sampling method.
The responses come from their subscribers and there's the issue of confirmation bias. |
12-17-2010, 02:51 PM | #3 |
One cam is enough
130
Rep 6,801
There's more wrong with these cars than just the HPFP. It's just that the HPFP is such a glaring issue that the other problems get washed into the background. The entire fueling system is prone to failure, there's carbon buildup galore, there have been plenty of people with electrical problems (many undiagnosable and recurring), rattling wastegates, and I've seen other off-the-wall-but-rare stuff like permeable blocks, rear main seals, transmission seals, and other stuff going on here. I'm sure I'm missing a bunch, but I don't really think I need to get into any more detail. You get my point.
I dunno about 35th out of 35, but it should undoubtedly place near the bottom. BMW promising to fix the HPFP every time it breaks is NOT an acceptable offset to the occurence of such a failure. Therefore, every HPFP failure, whether covered under warranty or not, is a failure and a strike against reliability. |
12-17-2010, 02:57 PM | #4 | |
72
Rep 1,217
As it stands, the hpfp issue is a concern from a reliability standpoint when compared to other Lux car manufacturers. Even though BMW warrants it for 100k miles, it's still an inconvenience the consumer should not have to deal with. |
12-17-2010, 03:52 PM | #5 |
146
Rep 1,922
Drives: E90 335i, E70 X5
good! now i can tell my family/friends that i have the most unreliable upscale car in the Consumer Report
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
12-17-2010, 04:05 PM | #7 |
177
Rep 1,105
Consumer Reports does have flaws, but I believe it. There was a great expose' a few months back on "the truth about cars" regarding faluts in the CR methodology. True Delta is an alternative that is in some ways better.
But, for the 335i, I belive it. This has been the best to drive and worst to own car I've ever had (CR shows very high owner satisfaction with the 335i BTW). In 42k miles, I've had... -Vanos solenoids -Cam Bearing ledge -transmission leak -long cranks -faulty software introducing lag -squeaky wheel syndrome -overheating due to lack of oil cooler -RF interference with the key -a few other minor issues I'm CPO, so I'm good for a while, but this along with all the electronic things that can go wrong, and the expense of simple things like changing the battery, give me pause. Wonderful car to drive though. |
12-17-2010, 04:16 PM | #8 | |
11
Rep 122
12-17-2010, 04:33 PM | #10 | |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England Last edited by captainaudio; 12-17-2010 at 04:38 PM.. |
12-17-2010, 04:47 PM | #12 | |
1705
Rep 14,829
-Vanos solenoids--car performing as designed -long cranks--car performing as designed -faulty software introducing lag--car performing as designed -squeaky wheel syndrome--car performing as designed -RF interference with the key--car performing as designed -a few other minor issues--car performing as designed |
12-17-2010, 04:48 PM | #13 |
1705
Rep 14,829
12-17-2010, 05:00 PM | #14 |
BMW Addict
102
Rep 792
'11 Black Sapphire F10 550i l ZSP l Avant Garde 20" M310
12-17-2010, 05:18 PM | #15 |
39
Rep 1,558
True
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
12-17-2010, 05:35 PM | #16 | |
177
Rep 1,105
So...squeaky wheel is as designed, eh? Must be a feature to let people know your car is starting to move. You should make sure all the new cars on the lot do it, and ask the dealer how he's going to fix them if they don't. On the good side, I think we've already had every common problem except the wastegate rattle and the HPFP failure. Water pumps are semi-common. Maybe the car is sorted out now. |
12-17-2010, 05:48 PM | #17 | |
1705
Rep 14,829
12-17-2010, 05:49 PM | #18 |
45
Rep 1,754
My E36 M3 was in the shop once for warranty repairs. I have a thick file on the 335 already...
If it has to go back in again, I'm gettin' one of these: |
12-17-2010, 05:54 PM | #19 | |
Rep 181
Doesn't seem like an issue to me; it's like buying a bad stock; you don't truly lose anything until you sell. Unfortunately, if you have to qualify for a loan, I am sure the bank is reducing the value too. This is what happens when the vendor doesn't listen to the customer. Consumer Reports actually nailed the car hard in 2009, so those buyers were probable to get a discounted buy (no big money loss...anyone who did their homework shouldn't have paid full price in general) |
12-17-2010, 05:56 PM | #20 |
Rep 181
12-17-2010, 09:17 PM | #21 |
81
Rep 1,656
I have had few minor issues with wind noise from the rim less doors, brakes squealing, creaking noise from the rear seats center stack and B pillars, as well as day time running lights going out and my i-drive jamming up with SOS malfunction.
But to BMW's credit all of these issues have been taken care of under warranty. Knock on wood I have not had any hpfp issues so far. I do however feel that BMW needs to pay greater attention to reliability as there sales keep climbing.
nickname"BAD 3",MHD E85 tune,RennArt catback non-resonated exhaust,VRSF Downpipes, VRSF 7"FMIC,VRSF stock side inlets,SSQV BOV,ECS CP,M-performance alcantara steering,retrofit M3 paddle shifters,Alpina B3 tranny flash,AFE power seal CAI,LED angels,ST Coilovers,M3 upper/lower control arms,E93 M3 Front Swaybar ,235/35/19x9 ,275/30/19x9.5. M sport bumpers, CF diffuser. When in doubt..flat out.
12-17-2010, 10:07 PM | #22 |
Rep 84
I bought my car as a CPO in July 2010 with 20,000 miles. So far it's spent 3 and 1/2 weeks at the dealership and I've been there 5 times. Main reason is wastegate rattle (2 1/2 weeks) auto dimming mirror not working (so far 1 week still at the dealership). Hasn't left me stranded or affected performance, but a higher end car should not have that horrible rattle sound or mirrors that don't dim!
